September 20, 2026, 09:37:48 pm
**edit** You can actually turn that feature off in the settings menu if you want.
No problem, I thought mine was messed up too actually. But then when I read through the rules with a fine tooth comb..I found the part about getting a letter for free..for each new ball! **edit** You can actually turn that feature off in the settings menu if you want.Cheers!!
On your first multiball, the first switch you trigger each ball spots a letter. You can also gain a "cheat" GREED letter by tilting. When G-R-E-E-D is spelled, the bookcase opens and the vault is revealed.
No it means before you get your FIRST multiball you get <a onMouseOver="javascript:window.status='a free';return true;" onMouseOut="javascript:window.status='';return true;" href="http://canadasrv.info?v=1%2E2&ss=a+free">a free</a> letter on each new ball. Once you get past the first multiball it doesnt happen anymore. TRUST me. Thats the way it works..PERIOD..
