Author Topic: MAME effects causes some games to only cover 1/4 of the screen? [SOLVED!]  (Read 1937 times)
dekar24k
  • Last login:April 28, 2019, 03:50:11 pm
    • ArcadeForum.com
Ok, so I'm 99% done configuring my arcade cab now  :applaud:, there are only minor issues left which I'm going to (hopefully) solve today.
One of the issues is related to effects in MAME. Every game works perfectly now, except that after I added the effect overlay 'Aperture1x2rb_Aaron' some games tend to only cover 1/4 of the screen (e.g. Turtles in Time). Is this a common problem and does anyone know a way around this?
I'm using MA 2.10 and MameUI32 v0.130u3.
« Last Edit: April 18, 2009, 01:57:05 pm by dekar24k »
Finished project: "The Saloon Arcade" - 2 player upright cabinet
Joystick.net - Retro gaming news and reviews
Ginsu Victim
  • Comanche, OK -- USA
Re: MAME effects causes some games to only cover 1/4 of the screen?
« Reply #1 on: April 18, 2009, 12:01:32 pm »
Do you have the automatic resolution switching on? If so, turn it off and see if that helps. Also, make sure it isn't auto-switching the refresh rate.
dekar24k
    • ArcadeForum.com
« Reply #2 on: April 18, 2009, 12:26:26 pm »
I have both Resolution > Size: Auto and Refresh: Auto in MameUI32 v.130u3, but I can't select anything else than 'Auto' from the dropdown boxes.
Funny thing is that the only game it has happened to so far is the Turtles-game.   :dunno
Ginsu Victim
« Reply #3 on: April 18, 2009, 12:31:46 pm »
Select your display instead of AUTO and see if it lets you change those.
« Last Edit: April 18, 2009, 12:34:34 pm by Ginsu Victim »
dekar24k
    • ArcadeForum.com
« Reply #4 on: April 18, 2009, 12:39:20 pm »
When I selected the display I could choose from different resolutions and refresh rates. I tried every resolution leaving the refresh at 60hz (LCD) but it didn't have any impact on the game.
Ginsu Victim
« Reply #5 on: April 18, 2009, 01:06:03 pm »
Hmmmm......
anyone got the answer?
dekar24k
    • ArcadeForum.com
« Reply #6 on: April 18, 2009, 01:56:45 pm »
Solved it, had to choose View: Pixel Aspect. Works perfect now. :)
Ginsu Victim
Doesn't sound like that should've caused it, but I'm glad it works.
dekar24k
    • ArcadeForum.com
Thanks. :) Now I only have to find out why GENS doesn't work with Maximus Arcade (sound gets all distorted), then I can finish my cabinet.  :cheers:
dekar24k
    • ArcadeForum.com
Used GENS+ instead. Works perfectly. Time to mount the bezel, the backpanel and then .. it's done. Finally!  :notworthy: :notworthy:
