Author Topic: Sanyo 20 EZV  (Read 2992 times)
nd4w
  • Last login:June 22, 2009, 10:50:24 am
Sanyo 20 EZV
« on: March 06, 2009, 04:32:11 pm »
I just got a Donkey Kong Jr with the Sanyo 20 monitor and it is blowing the 250v 300 ma fuse, I don't see any visuals that would indicate a problem. Any suggestins ?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Sanyo 20 EZV
« Reply #1 on: March 07, 2009, 03:44:54 pm »
schematic here : http://playchoice.riemen.net/downloads/manuals/Sanyo-EZV.pdf
the reg drive ic may be questionable, faulty pass xistor.
check c609 ,    c610 ? ( diff to make it out on print . near pin 2 on reg drive IC )
if fuse blows hard ( flashbulb ! ) possible shorted hot/fly issue...
4 land call ?   pm for net text  "qso"
qrz
nd4w
Re: Sanyo 20 EZV
« Reply #2 on: March 07, 2009, 08:05:27 pm »
Thanks , great info , c 610 looks pretty bad, I am re capping it Monday.
Mike
nd4w
Re: Sanyo 20 EZV
« Reply #3 on: March 09, 2009, 05:12:56 pm »
re capped monitor and audio board, not blowing 300 ma fuse now , but r609 getting red hot and no picture or sound. What next ? Also where can I get a replacement for r609, ceramic ?
Mike
qrz
Re: Sanyo 20 EZV
« Reply #4 on: March 09, 2009, 10:07:06 pm »
r609 is the "pass resistor" (180 ohm/20w)
 high load condition ?   check ur hot for a short....surprised not poppin' the line fuse (4a)
qrz
nd4w
Re: Sanyo 20 EZV
« Reply #5 on: March 10, 2009, 09:35:19 pm »
I've looked for a replacement for the 20 watt 180 ohm, got any ideas on where I can find one? I'll check the HOT
Mike
