Author Topic: Help with getting chd file to work  (Read 2831 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: June 26, 2003, 09:40:43 pm »
I have the area 51/ maximum force chd. but I'm not sure what the file should be labled as or what the name of the folder it goes in should be called. any ideas?
Generic Eric
Re:Help with getting chd file to work
« Reply #1 on: June 26, 2003, 10:07:24 pm »
From the A.G.M (alt.games.mame for the uniniated) FAQ
Scroll down until you get to 4.9
Shieldwolf
  • SpearShield.com
« Reply #2 on: June 26, 2003, 11:59:42 pm »
right kinst is like that and works
however trying to play area51/mx with all software needed and right results brings up an error about not having chd for area51
SirPeale
  • Green Mountain Man
« Reply #3 on: June 27, 2003, 10:24:57 am »
You did put the 'area51mx.chd' file into a directory named 'area51mx', correct?  Just off your ROMS directory?
Shieldwolf
  • SpearShield.com
« Reply #4 on: June 27, 2003, 09:59:04 pm »
yes I did. can some verify the size of the file. maybe that's my problem. My file is 1,749,418 kb
SirPeale
« Reply #5 on: June 27, 2003, 11:16:25 pm »
That's correct on my end.
So...what you're saying is your structure looks like this:
C:\MAME
C:\MAME\ROMS
C:\MAME\ROMS\area51mx.zip
C:\MAME\ROMS\AREA51MX\area51mx.chd
Is that correct?  And you're still having problems?
What is the exact error you're getting?
Shieldwolf
  • SpearShield.com
« Reply #6 on: June 28, 2003, 12:22:54 am »
yes and now for whatever reason it works actually opened the zipped chd file and then re zipped it. I don't know why but now it works.
Thanks for trying to help guys
SirPeale
« Reply #7 on: June 29, 2003, 12:43:52 pm »
Wait...you had the CHD file zipped?  That's why it wouldn't work.
Shieldwolf
  • SpearShield.com
« Reply #8 on: June 29, 2003, 01:29:31 pm »
no what i mean is I rezipped the filed renamed it then unzipped it
spectre
  • -- banned --
  • Last login:April 07, 2004, 08:45:11 am
  • -- banned --
« Reply #9 on: June 29, 2003, 08:40:37 pm »
the chd file must be the original name as it was when you downloaded it
in a folder of the same name or loose in your mame directory one of those 2 i forget which
then you must have the roms to go with it in a proper folder
-- banned --
SirPeale
« Reply #10 on: June 30, 2003, 02:06:54 pm »
I guess I still don't get it.  I'm not sure where you got your CHD from, but the burners span them into either RARs or spannign ZIPs.  They need to be uncompressed/unspanned to work.  Although they WILL work if placed in the same ZIP as the ROMs, it's not recommended.
Is that what you did?  Placed the .chd file with the ROMs?
