Author Topic: Tekken 1 harness questions  (Read 1313 times)
joshwaan
  • Last login:April 24, 2017, 07:51:23 pm
« on: February 19, 2009, 04:56:23 pm »
Hi Guys
I bought Tekken my first arcade board, booted it up last like goodmorning loved that.
I have only 1 speaker plugged in. I have this http://www.jammaboards.com/store/namco-48-pin-kick-harness/prod_145.html?ccSID285e73f64c04744fc5f33ff68f529742=bb5629ec73e952e293e236d3ec6c65be
But I have no solder skills can I put quick connects on this, if so how and what do I need?
Where do I plug the speaker - + into this extra connector?
Josh
srarcade
  • Last login:June 18, 2018, 03:16:29 pm
Re: Tekken 1 harness questions
« Reply #1 on: February 20, 2009, 05:13:41 pm »
No solder skills needed (nor recommended for things like harnesses, they should be modular to be removeable). All you need to do is pick up a crimp tool like this one http://www.mcmelectronics.com/product/22-1795 and some 16 or 18 AWG quick disconnects and you're set. Crimper is a very easy to use tool and a necessity for this hobby, you can find them from anywhere between $10 and up.
The speaker does not connect to this at all. This only gives connection for 3 extra buttons per player and a extra ground wire per player, but you can just daisy chain from the other buttons for ground.
« Last Edit: February 20, 2009, 05:15:43 pm by srarcade »
