May 18, 2026, 06:51:41 pm
Doggone, I don't type fast enough! At least the part about the real scoreboard saves me from having posted a complete repeat of Brian's post.
You can do it using a real scoreboard, or with an overlay from the command line (-useoverlaysb <overlay number>). I think it's also an option in the configuration menu, so you can turn it on there and then check the log for the correct command.
