Author Topic: Extremely basic LED questions  (Read 1409 times)
ItchyD
  • Last login:July 08, 2017, 03:38:24 pm
« on: January 24, 2009, 04:02:29 pm »
Ok so I got a nice batch of LEDs from groovy game gear for my electric ice buttons now I need to learn to wire them.  I have the resistors, and I'm planning to take power from the molex connector in my power supply.
Which leg do I stick the resistor to?
Can I wire up my ( 8 ) led's and resistors in parallel and not have a problem?
I know I should know this but what do I hook the other leg to???   :dunno  the ground in the molex connector I guess?
Since I'm a sissy when it comes to soldering is there a way I can get away without it?  like very small crimps or something
I'm going to have to bend the legs of the LED at a right angle to make them work with the button is this going to break off the legs?
csa3d
  • Will game for food
    • Galaxian Mame Conversion
Re: Extremely basic LED questions
« Reply #1 on: January 24, 2009, 04:20:10 pm »
At the top of the forum page, you'll find a button that looks like this
From there, you type in "led wiring" and hit search.  On the top of the results list I found this link for you.  Should be a good start.
Report back with your results for others if you found other information while doing your searches.
-csa
cyapps
  • Last login:January 04, 2011, 02:51:31 pm
« Reply #2 on: January 25, 2009, 06:35:07 pm »
I wouldn't worry about it, I am about to start the wiring process of my leds and I have been playing around with a led and have bent it around a few times and it has yet to break (just don't over do it).
