Author Topic: vpinball on vertical monitor???  (Read 1441 times)
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« on: June 21, 2003, 11:17:04 pm »
Well, now I've discovered visual pinball, one more thing to add to my planned cab.  Was thinking, pinball machines are vertically oriented, perfect for a cabinet with vertical monitor?  but, vp displays horizontally in Windows.  Just wondering, does it work on vertical monitor, would it be "squished", anyone else try this?
Thanks,
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
Re:vpinball on vertical monitor???
« Reply #1 on: June 22, 2003, 12:39:14 am »
yeah it works very good but only if your vidcard supports hardware accellerated rotation of the desktop...for example all gefoece ti's under win 2k/ win xp.
Also because the layout is in most cases designed for 4:3 running it in windowed mode you can just show the middle part...gving a larger playfioeld view then on a horizontal monitor
peter
