Author Topic: Mearuring a curved CRT tube  (Read 1975 times)
Ummon
  • Trade Count: (+13)
« on: December 26, 2008, 06:44:35 pm »
What I'm really wondering here is whether a curved CRT is measured along an 'ideal plane', or if the actual curved surface of the tube is measured? Because, if it's the latter, then for example a 19" curved tube would be smaller than a 19" flat tube.
Yo. Chocolate.
Stephen Hawking
grantspain
Re: Mearuring a curved CRT tube
« Reply #1 on: December 26, 2008, 06:59:02 pm »
a 19" curved and 19" pure flat are the same as the measure is made as dead flat on the diagonal from corner to corner
the only real time the curvature comes into play is how it affects the bezel
i.e a nanao ms8-29fan in daytona use if replaced with a wei ya 2929 will leave a gap in the bezel---which is why happ supply a bezel filler with the makvision tri sync monitor that they champion as a replacement
Jack Burton
« Reply #2 on: December 26, 2008, 07:13:48 pm »
Wouldn't a curved glass with a diagonal flat measurement of 19" have a slightly larger surface area than one that had a flat screen?  After all, the curved glass is taking a longer route to go between two points.
grantspain
« Reply #3 on: December 26, 2008, 07:18:10 pm »
yeah but it is not important as it does not affect the size of the actual tube
Jack Burton
« Reply #4 on: December 27, 2008, 12:07:42 am »
So is the glass on the other side (the side inside the tube) flat on the other side?  I'm just curious, I've never broken apart a CRT.
Ummon
« Reply #5 on: December 28, 2008, 03:37:01 pm »
I think it's concave, because otherwise you'd have issues due to refraction. That might imply flat tubes are convex inside, though. Hmmm.
Yo. Chocolate.
Stephen Hawking
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #6 on: December 28, 2008, 07:59:32 pm »
it is the same as the face .  the reason flat crts have additional geometry circuitry, is due to the fact the electron beam will take a bit more time to reach the corners than center of screen.
some early tv crts ( < 1945 )  were round with a flat screen.   minor distortion was mostly ignored in those days.
see   http://www.earlytelevision.org/index.html
hey , a "good picture" was sometimes defined as seeing movement in the snow .   ;D
if anyone cares,  the oldest tv i've repaired to date was a 1948 zenith.  was a very interesting set !
qrz
« Last Edit: December 28, 2008, 09:37:09 pm by qrz »
