Author Topic: [s]Garbled edges of vertical lines[/s] I am lucky to be not dead :)  (Read 2262 times)
drawfull
Hi
I am new to monitors, with regard to having to make them work, so am looking for some advice.
I got a brand new noname 20" standard resolution monitor for my Gauntlet cab, but (apart from the brighness issue in this pic) I get awful wavy edges to all and any vertical lines.
At this time I  have not installed the degaussing coil and its shield braided cable, but I don't believe that would cause this prob. Any help much appreciated :)
EDIT: I am stupid and although I haven't attempted to fix the problem, I think I have been fckng lucky. I forgot to attach the ground strap to the chassis. I haven't touched the rear of the tube to check but my spider-sense tells me that this is likely to be sat at 25kV and almost certainly causing the problem (spider-sense = wiki here and google). I have had my hands everywhere in there tweaking pots while looking at the screen...  :-\
 :blowup:
The reason I didn't attach the ground was, erm, well, uh, because I couldn't find the pin to plug the header onto. What can it hurt, right? Well if I'm not totally off base I believe when I remove the door of my cab later I will see a single header on the neckboard PCB.
So yeah, I guess it's prudent to do more research before messing around with stuff you don't understand.
Stupid question 38: How the hell is the ground strap thing supposed to attach to the monitor anyway? It has three loops but I can't see any physical fixing points on the chassis.
Thanks in advance
n00b :(
« Last Edit: December 21, 2008, 10:09:00 am by drawfull »
grantspain
Re: [s]Garbled edges of vertical lines[/s] I am lucky to be not dead :)
« Reply #1 on: December 21, 2008, 04:49:34 pm »
the brightness issue is down to the screen volts being too high-hence the flyback lines
post some pics of what you are saying about the wiring as you are not making any sense
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: December 26, 2008, 03:24:36 pm »
not a stupid question .
each of the three loops go around the crt mouning ears .  usually the top/bottom left and the top right.
a spring connected to the braid will then connect to the bottom right and provide tension.
this usually done before mounting the crt  ;)
there should be a wire from braid to chassis ground, and to ground on the crt socket.
qrz
