Author Topic: Disable Windows Keyboard Shortcuts  (Read 5368 times)
LLUncoolJ
  • Last login:April 23, 2015, 03:08:00 pm
  • This snowflake tastes like fish sticks!
« on: December 15, 2008, 03:51:38 pm »
Anyone know of an easy was to disable windows keyboard shortcuts (ei ctrl + w)? I am using MaLa and every now and then while playing, we activate shortcuts by pressing combinations of buttons/joysticks. For example, we were playing the Simpsons and suddenly it goes to a windows explorer window. I'm pretty sure this is what's happening, but I must be overlookingthe obvious.
You probably remember me from such films as `The Revenge of Abe Lincoln' and `The Wackiest Covered Wagon in the West'
Gameroom pics at http://forum.arcadecontrols.com/index.php?topic=89006.40
Cakemeister
  • Last login:June 02, 2026, 11:00:20 pm
Old, but not obsolete.
LLUncoolJ
Re: Disable Windows Keyboard Shortcuts
« Reply #2 on: December 15, 2008, 04:42:54 pm »
Thanks, but the windows key isn't the problem. I am running off of a control panel with Ipac interface...no problems accidentally hitting the window key. It's the cntrol ant alt keys that seem to be causing problems.
I found this thread, but it is 5+ years old...hopefully there is some kind of solution since then.
http://forum.arcadecontrols.com/index.php?topic=7273.0
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #3 on: December 15, 2008, 06:27:31 pm »
The best solution is to not map buttons to ctrl or alt. I got tired of chasing these sorts of problems and finally realized there is absolutely no good reason for a typical cab to keep those default mappings.
LLUncoolJ
« Reply #4 on: December 16, 2008, 11:05:01 am »
Yeah, I guess I'll go into MAME and remap them globally. It will probably screw up my LED configuration, but I guess I have all winter to straighten it out.
LLUncoolJ
« Reply #5 on: December 17, 2008, 10:45:39 am »
Well, I set up MAME to use other keys than CRTL, ALT, and SHIFT. Now my IPAC won't reprogram. It's giving me some kind of driver error. I just programmed it a couple of weeks ago and nothing has changed. Man this is a frustrating hobby!
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #6 on: December 19, 2008, 01:52:35 pm »
Try re-installing the Ultimarc WinIPAC programing utility.  That installs the necessary driver.
