Author Topic: Light Bulb trick on a Kortek 2914F. Anybody??  (Read 4024 times)
jconstanza
  • Last login:April 23, 2009, 02:28:02 pm
« on: December 01, 2008, 01:00:35 pm »
Does anybody know how to do the light bulb trick on a Kortek KT-2914F chassis?
grantspain
Re: Light Bulb trick on a Kortek 2914F. Anybody??
« Reply #1 on: December 01, 2008, 01:13:07 pm »
got a link to the schematic?
MonMotha
grantspain
« Reply #3 on: December 01, 2008, 02:40:46 pm »
whats the problem?
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« Reply #4 on: December 01, 2008, 02:48:23 pm »
I think he means the test of the high voltage section of the chassis...  ?
jconstanza
« Reply #5 on: December 01, 2008, 03:23:01 pm »
Well I was trying to isolate the power supply because of the ticking noise I have coming from TH101. Here's what happen, I did a cap kit on it and stupidly reversed the cap on C615. I know it worked but after the cap popped then it started ticking. Idiot!
grantspain
« Reply #6 on: December 01, 2008, 03:31:48 pm »
you would need to check  diodes mate
D104,D105,D106
D108,IC103,IC101
grantspain
« Reply #7 on: December 01, 2008, 03:33:44 pm »
its difficult to see with the schem but you have killed a voltage,that repair guide is good so follow that
i bet you were trying to get rid of your whistle
grantspain
« Reply #8 on: December 01, 2008, 04:05:00 pm »
i am pretty sure to isolate the high voltage/flyback you need to desolder pins 1 and 6 of the flyback
bulb connect to chassis frame/ground and L106
i am sure the b+ on these multi syncs runs around 80v
would like someone to concur with this before you attempt this though
jconstanza
« Reply #9 on: December 01, 2008, 04:48:04 pm »
I replaced all those parts and still no luck. This monitor doesn't tick like the wells or neotec usually tick where all you here is just the tick. This one sort of actually turns on then off to the point where you can see something on the screen.
grantspain
« Reply #10 on: December 01, 2008, 05:02:27 pm »
you will need to go through all those components on the line of the cap that was reversed,there are test points to check voltages
those multi syncs also do this if the signal frequency or sync are not stable
