Author Topic: winVICE with mamewah?  (Read 4798 times)
sham69
  • Last login:June 12, 2015, 06:03:44 am
« on: December 01, 2008, 09:15:12 am »
Hi,
apologies if this has been answered but I can't find much info on it.
I am trying to get winvice working with mamewah, i have downloaded the winvice exe, the c64 wrapper, the c64 ini but can't seem to piece it together.
I know I should be following the way I have my working mame setup but just cant seem to get it.
Can anyone help me?
Thanks.
Sham.
sham69
Re: winVICE with mamewah?
« Reply #1 on: December 07, 2008, 11:51:27 am »
Decided to keep trying and have gotten a bit further.
I can see the emu in the platform choice of Mamewah and can get the list of games generated but when I try to launch a game it just hangs..
Can anyone help?
Thanks.
gonzo90017
« Reply #2 on: December 07, 2008, 11:47:35 pm »
Post your ini file.
sham69
« Reply #3 on: December 08, 2008, 01:32:23 pm »
Sorry...
Thanks..
### WinVice.ini (mamewah v1.63) ###
emulator_title WinVice
### List Generation Settings ###
rom_path C:\emulators\Programs\WinVICE-1.22\C64DISKS
rom_extension t64;d64;prg
dat_file
nms_file
catver_ini_file
list_generation_method rom_folder
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline C:\emulators\Programs\WinVICE-1.22\x64.exe -autostart "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths
movie_preview_path
movie_artwork_no 1
enable_fuzzy_search 0
history_dat_file auto
history_dat_artwork_no 2
### Screen-Saver Settings ###
enable_music_in_screensaver 1
select_random_game 0
saver_type gamelist_slideshow
movie_path
movie_fullscreen 1
quit_delay 0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display [description]{scroll}
### Settings used by MAMEWAH ###
current_list 0
gonzo90017
« Reply #4 on: December 08, 2008, 04:12:57 pm »
The wrapper isn't needed, and anyways it doesn't seem you're using it.
Is there any reason you're using the 1.22 version instead of the newer 2.0 version?
http://www.zimmers.net/anonftp/pub/cbm/crossplatform/emulators/VICE/WinVICE-2.0.zip
This is what you're command line should look like:
Code: [Select]
C:\emulators\Programs\WinVICE-2.0\x64.exe -fullscreen +confirmexit -autostart "[rompath]\[name].[romext]"{dosbox}{safelaunch}
Also for some reason it wouldn't load my zipped games. Make sure they're unzipped.
These are the extensions i'm positive it supports:
Code: [Select]
D64;T64;x64
sham69
« Reply #5 on: December 08, 2008, 05:49:15 pm »
Cheers for the reply yeah not using the wrapper
Roms are .d64 so should be cool thought 1.22 was the latest version I will try the new version and try your commandline
sham69
« Reply #6 on: December 10, 2008, 05:32:13 am »
tried this last night and its still not working.
I can see the emu trying to load but its a small window and then it just hangs.
I am getting further but not sure where to go from here.
If I try to run it from a commandline forgetting about mamewah it works fine?
gonzo90017
« Reply #7 on: December 10, 2008, 01:13:25 pm »
Try changing
Code: [Select]
{safelaunch}to
Code: [Select]
{nosafelaunch}
sham69
« Reply #8 on: December 10, 2008, 02:27:50 pm »
tried it again today and now its not running from commandline?
I am using remote desktop from my pc to the cab and running commandline from there so don't know if thats the problem.
Here is what winvice is telling me...
*** VICE Version 2.0 ***
Welcome to x64, the free portable C64 Emulator.
Current VICE team members:
A. Boose, D. Lem, T. Biczo, A. Dehmel, T. Bretz, A. Matthies,
M. Pottendorfer, M. Brenner, S. Trikaliotis, M. van den Heuvel,
C. Vogelgsang, Fabrizio Gennari.
This is free software with ABSOLUTELY NO WARRANTY.
See the "About VICE" command for more info.
Loading system file `C:\emulators\Programs\WinVICE\C64\kernal'.
C64MEM: Kernal rev #3.
Loading system file `C:\emulators\Programs\WinVICE\C64\basic'.
Loading system file `C:\emulators\Programs\WinVICE\C64\chargen'.
LoadLibrary opencbm.dll failed!
Loading system file `C:\emulators\Programs\WinVICE\PRINTER\mps803'.
Palette: Loading palette `C:\emulators\Programs\WinVICE\PRINTER\mps803.vpl'.
Loading system file `C:\emulators\Programs\WinVICE\PRINTER\nl10-cbm'.
NL10: Printer driver initialized.
Loading system file `C:\emulators\Programs\WinVICE\DRIVES\dos1541'.
Loading system file `C:\emulators\Programs\WinVICE\DRIVES\d1541II'.
Loading system file `C:\emulators\Programs\WinVICE\DRIVES\dos1570'.
Loading system file `C:\emulators\Programs\WinVICE\DRIVES\dos1571'.
Loading system file `C:\emulators\Programs\WinVICE\DRIVES\dos1581'.
Loading system file `C:\emulators\Programs\WinVICE\DRIVES\dos2031'.
Loading system file `C:\emulators\Programs\WinVICE\DRIVES\dos2040'.
Loading system file `C:\emulators\Programs\WinVICE\DRIVES\dos3040'.
Loading system file `C:\emulators\Programs\WinVICE\DRIVES\dos4040'.
Loading system file `C:\emulators\Programs\WinVICE\DRIVES\dos1001'.
Drive: Finished loading ROM images.
Refresh rate: 00369E99 / 7.00 = 511363.563
RGB surface...
dwRGBBitCount: 16
dwRBitMask: 0000f800
dwGBitMask: 000007e0
dwBBitMask: 0000001f
RGB surface...
dwRGBBitCount: 16
Sound: Available sound devices: dx wmm dummy fs speed dump wav voc iff aiff ffmpegaudio
TFEARCH: LoadLibrary WPCAP.DLL failed!
Keyboard: Loading keymap `C:\emulators\Programs\WinVICE\C64\win_pos.vkm'.
AUTOSTART: Autodetecting image type of `[rompath]\[name].[romext]{dosbox}{nosafelaunch}'.
Filesystem Image: Error - Cannot open file `[rompath]\[name].[romext]{dosbox}{nosafelaunch}'.
Tape: Error - Cannot open file `[rompath]\[name].[romext]{dosbox}{nosafelaunch}'
AUTOSTART: Error - Cannot open `[rompath]\[name].[romext]{dosbox}{nosafelaunch}'.
AUTOSTART: Error - `[rompath]\[name].[romext]{dosbox}{nosafelaunch}' is not a valid file.
Main CPU: starting at ($FFFC).
Main CPU: RESET.
Sound: Opened device `dx', speed 22050Hz, fragment size 23ms, buffer size 371ms
reSID: MOS6581, filter on, sampling rate 22050Hz - fast
Sound: Warning - Buffer drained
RGB surface...
dwRGBBitCount: 16
Exiting...
Sound: Closing device `dx'
gonzo90017
« Reply #9 on: December 10, 2008, 03:10:32 pm »
The reason it isn't loading from the command line is because you're using
Code: [Select]
"[rompath]\[name].[romext]"{dosbox}{nosafelaunch}This should only be used with mamewah's ini files.
You have to specify the entire path when running it directly from the emulator. In my case:
Code: [Select]
x64.exe -fullscreen +confirmexit -autostart "C:\Documents and Settings\Main Man\Desktop\WinVICE-2.0\1942 (1986)(Elite)[cr 1001].zip"
sham69
« Reply #10 on: December 10, 2008, 04:03:55 pm »
Thanks so much Gonzo finally got it working, had to change a few settings in the GUI aswell, PAL emulation and couple of other things so have it working from the emulator.
Now how do I get it to run from Mamewah...
Thanks.
sham69
« Reply #11 on: December 13, 2008, 11:15:34 am »
Still having problems running this from mamewah.
I am confused about the ini files.
The way I have it setup is I have a folder structure c:/emulators/programs/winvice
This is where the winvice install is along with the .exe and the roms (in C64ROMS folder)
Within the mamewah(1.63) folder I have a config folder where I have a winvice folder with an ini file.
Could somebody explain the ini files as I have done so much changing them around I think I might have messed up.
Here is the latest error I am getting.
I can see the list of games in Mamewah but when I try to load one I can see the emu opening and then it crashes the pc?
Thanks for your patience.
RGB surface...
dwRGBBitCount: 16
AUTOSTART: Autodetecting image type of `[rompath]\[name].[romext]{dosbox}{safelaunch}'.
Filesystem Image: Error - Cannot open file `[rompath]\[name].[romext]{dosbox}{safelaunch}'.
Tape: Error - Cannot open file `[rompath]\[name].[romext]{dosbox}{safelaunch}'
AUTOSTART: Error - Cannot open `[rompath]\[name].[romext]{dosbox}{safelaunch}'.
AUTOSTART: Error - `[rompath]\[name].[romext]{dosbox}{safelaunch}' is not a valid file.
Main CPU: RESET.
Drive 8: RESET.
Drive 8: RESET.
Filesystem Image Probe: D64 disk image recognised: C:\emulators\Programs\WinVICE\C64DISKS\10-Pin Bowling (1984)(CDS Microsystems)(cr CHR)(a2).d64, 35 tracks (read only).
VDrive: Unit 100: D64 disk image attached: C:\emulators\Programs\WinVICE\C64DISKS\10-Pin Bowling (1984)(CDS Microsystems)(cr CHR)(a2).d64.
VDrive: Unit 100: D64 disk image detached: C:\emulators\Programs\WinVICE\C64DISKS\10-Pin Bowling (1984)(CDS Microsystems)(cr CHR)(a2).d64.
Filesystem Image Probe: D64 disk image recognised: C:\emulators\Programs\WinVICE\C64DISKS\10-Pin Bowling (1984)(CDS Microsystems)(cr CHR)(a2).d64, 35 tracks.
DriveImage: Unit 8: D64 disk image attached: C:\emulators\Programs\WinVICE\C64DISKS\10-Pin Bowling (1984)(CDS Microsystems)(cr CHR)(a2).d64.
VDrive: Unit 8: D64 disk image attached: C:\emulators\Programs\WinVICE\C64DISKS\10-Pin Bowling (1984)(CDS Microsystems)(cr CHR)(a2).d64.
Writing configuration file `C:\emulators\Programs\WinVICE\vice.ini'.
Exiting...
fdc: Unit 8: D64 disk image detached: C:\emulators\Programs\WinVICE\C64DISKS\10-Pin Bowling (1984)(CDS Microsystems)(cr CHR)(a2).d64.
DriveImage: Unit 8: D64 disk image detached: C:\emulators\Programs\WinVICE\C64DISKS\10-Pin Bowling (1984)(CDS Microsystems)(cr CHR)(a2).d64.
VDrive: Unit 8: D64 disk image detached: C:\emulators\Programs\WinVICE\C64DISKS\10-Pin Bowling (1984)(CDS Microsystems)(cr CHR)(a2).d64.
