Author Topic: Mame 128U3 Ultimate Mortal Kombat 3  (Read 13574 times)
Hunk_4TH
  • Last login:January 21, 2026, 09:48:13 pm
  • I DON'T ALLOW VANDALISM IN MY STOOOOOOOOOOORE!
« on: November 19, 2008, 07:27:11 pm »
Hey guys I've been having a problem with loading UMK3 in the latest Mame update. Each time I try and load it up I get a missing files error. But it works perfectly in previous/older versions. This is from the latest set. Any ideas? And is anyone else having this problem?
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
Re: Mame 128U3 Ultimate Mortal Kombat 3
« Reply #1 on: November 19, 2008, 08:07:32 pm »
You'll have the problem until you update the romset.  Read up on why romsets can potentially change from version to version in the MAMEDEV.ORG FAQ Page:  http://mamedev.org/devwiki/index.php/FAQ:ROMs#Why_does_MAME_report_.22missing_files.22_even_if_I_have_the_ROMs.3F
UMK3 (Ultimate Mortal Kombat 3) used to be listed as a clone of MK3 (Mortal Kombat 3).  This was changed in MAME 0.128u1 so that UMK3 is now it's own parent set (with UMK311, UMK312 now being listed as clones of UMK3) largely since they are, by title and content, different than normal MK3 and thus should be treated as a different game.
Hunk_4TH
« Reply #2 on: November 19, 2008, 08:15:33 pm »
Oh wow I didn't realize they separated it from MK3 thanks for the info! I guess I'll have to wait till a new set is released. as I can't find it.
Sardu
  • Last login:April 08, 2023, 05:45:54 pm
« Reply #3 on: November 22, 2008, 01:18:29 pm »
The missing roms are in the MK3 set.   Just look and see which ones are missing when you try to load UMK3 and you'll find them there(in the MK3 set).
OR just copy the whole MK3 set into your UMK3 set/zip and it will work.
Same thing goes for NBA Jam TE and NBA Jam.  (not sure if they did this with any other game)
« Last Edit: November 22, 2008, 01:20:27 pm by Sardu »
Hunk_4TH
« Reply #4 on: November 22, 2008, 03:57:59 pm »
I never thought of that but it does make sense. Thanks a lot for the tip. Now I can compile back to U3.I'll give it a shot!  :cheers:
havic626
  • -banned-
  • Last login:August 05, 2012, 05:11:42 am
« Reply #5 on: November 28, 2008, 10:29:26 am »
never new there was a problem till i read this, thnx for the fix
Hunk_4TH
« Reply #6 on: November 28, 2008, 03:56:23 pm »
Same here. But it's a good thing they did fix it so it isn't listed as a clone now. And the fix did work thanks!  :cheers:
DaniCelebration
  • Newbie
  • Last login:September 16, 2009, 02:43:55 pm
« Reply #7 on: September 13, 2009, 06:10:13 am »
Hello!
I launched UMK3 the way it's mentioned here, but I noticed it causes problems in the intro (only the 4 new characters get their bio's shown) and with the fighting backgrounds (the 4 UMK3 levels cycle several times before the old MK3 stages start to appear), I wonder if it's possible to fix all that?
