Author Topic: Multimeter Diode test work as continuity test?  (Read 3298 times)
Epyx
  • "You're an oddity"
« on: November 19, 2008, 02:40:56 pm »
I recently purchased:
Link
Now before anyone jumps on me for not reading up on electronics before creating my own circuit boards...rest easy...I have one purpose only and its a simple one to have the multimeter assist me with a continuity test for testing wires on portable CP wiring.  I have no ambitions beyond CP wiring...no high voltage stuff here! :)
Now the unit I purchased doesn't seem to have a dedicated continuity test but it does have a diode test.  When I use the diode test to test wires etc I get readings when its the same wire and 0 when it isn't.
Would this in a sense work just like a continuity test?
« Last Edit: November 19, 2008, 02:55:54 pm by Peale »
Last Project
Epyx Tutorials:
Tutorials
SirPeale
  • Green Mountain Man
Re: Multimeter Diode test work as continuity test?
« Reply #1 on: November 19, 2008, 02:56:55 pm »
Generally you want to use the ohms setting for that unless your diode test beeps when you use it.
Epyx
« Reply #2 on: November 19, 2008, 03:00:24 pm »
Okay thanks Peale...the manual is pretty sparce so thought id ask!
Ill try 0hms.
Last Project
Epyx Tutorials:
Tutorials
