Author Topic: pc booting problem on arcade monitor  (Read 1401 times)
juice lee
  • Newbie
  • Last login:November 09, 2008, 10:57:02 pm
« on: November 05, 2008, 11:27:42 am »
i formated installed xp and drivers for 7800gtx set resolution to 640x480 60hz, and i still getting problems when i boot with arcade monitor pluged in(bad clicking noise on the post)
it is fine if i boot with pc monitor then change it in display to the arcade monitor
i am using a j pac which is switched to 15 khz and set soft 15 khz up and arcade monitor is samsung
here is link to my cab  http://www.arcadecabinets.co.uk/index.php?option=com_content&task=view&id=12&Itemid=32 pic of cab
here is a video link of what happen
you will see soon as ram finish, clicking start
here is link to inside cab
i have not had this trouble with arcade vga 2 pcie
thanks for your time
« Last Edit: November 05, 2008, 12:22:45 pm by juice lee »
