Author Topic: Changing Game Specific Parameters on MameUI to use on Hyperspin (or Atomic)?  (Read 4565 times)
Charles4400
  • Last login:February 18, 2016, 02:31:42 am
How exactly can you use MameUI to change specific Game parameters which FE's like Hyperspin and Atomic FE will recognize?
I assume all the changes I make on MameUi are written onto a file (which file?) so if I have an existing gamelelist (or want to create a new gamelist) on Hyperspin or Atomic...how do I get those FE's to recognize the changes made in MameUI?
Right now on existing and new gamelists on Hyperspin, any changes I make in MameUI are not recognized..... :-\
ahofle
    • Arcade Ambience Project
Run MAMEUI from the same directory as you run MAME in Hyperspin.  Global changes end up in mame.ini and game specific changes go under the ini folder, named after the game you change (ie. pacman.ini or galaga.ini).
Charles4400
Thanks! This helps!
