Author Topic: joystick (analog) configuration with Advancemame issue  (Read 4511 times)
Ummon
  • Trade Count: (+13)
« on: October 20, 2008, 03:58:39 am »
I searched the threads and found what people have done with Mame/Mame32, but Advancemame seems to denote things (or at least behave) differently and I can't figure out how to set it to avoid the conflict between my U360 and my trackball or spinner (depending on the game controls). Essentially, it favors the stick, locking out input from the trackball or spinner.
This is the syntax:     input_map[p1_stickx] joystick[0,0,x] -joystick[0,1,x]
                                  input_map[p1_sticky] joystick[0,0,y] -joystick[0,1,y]
I'm assuming the first number is the stick ID, the second the direction of rotation, but when I change the first number nothing happens. Of course the direction changes when I change the second number.
Has anyone this problem with a joystick in Advancemame?
« Last Edit: November 10, 2008, 09:44:55 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
Ummon
Re: joystick (analog) configuration with Advancemame issue
« Reply #1 on: October 23, 2008, 06:32:10 pm »
edit
« Last Edit: November 10, 2008, 09:42:20 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #2 on: November 10, 2008, 09:42:53 pm »
Re-worked and bumped
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #3 on: November 20, 2008, 12:31:52 am »
Okay, I tried something new. I found out that if you put in 'none' for device_joystick, then that turns off input from an analog stick. Of course I don't want this for most games, so I put in entries for each spinner and trackball game. It turns off the stick, but only input from spinners is being allowed. Still no ball input is being allowed.
« Last Edit: November 21, 2008, 03:47:50 am by Ummon »
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #4 on: November 21, 2008, 05:02:12 am »
Well, I looked at the docs for a long while more and it seems that the same driver is used for trackball and joystick input. Or, rather, that trackball is under analog input. Weird. I can't imagine someone out there using Advancemame hasn't used a trackball and an analog stick together in their system, and either encountered this, or not. Anyone out there?
« Last Edit: November 21, 2008, 05:32:05 am by Ummon »
Yo. Chocolate.
Stephen Hawking
tikbalang
  • Last login:May 07, 2013, 05:04:54 pm
    • MAME BootCD's for DOS
« Reply #5 on: November 21, 2008, 09:37:00 am »
this link is the opposite of what you are trying to solve, but maybe you can get something out of the configuration principle used:
(analog games with digital stick, spanish)
http://zonaarcade.forumcommunity.net/?t=6132377
Ummon
« Reply #6 on: November 23, 2008, 02:06:33 am »
Well, that's in spanish so I don't know if I get it, but it seems they're setting the directions to 'none' and selecting the 'analog' input...but I don't at the moment know how to set that. I'll have to look.
« Last Edit: November 23, 2008, 02:10:32 am by Ummon »
Yo. Chocolate.
Stephen Hawking
