Author Topic: Largest Mameroom PC Monitor Which Will Fit?  (Read 2345 times)
Charles4400
  • Last login:February 18, 2016, 02:31:42 am
« on: October 11, 2008, 08:43:53 pm »
Well I have deccided I want to get a PC monitor for the Mameroom Cabinet I am building but am having a heck of a time finding large ones (ideally 27" viewable).
I am going to try using the ultimarc ArcvadeVGA2 as it claims to reproduce the classic look on PC monitors. This also gives flexibilty on playing newer games on the cabinet as well. (Sound good to you guys? think that's a good idea?)
Anyways, does anyone know of a SVGA monitor that still exists which is ideally 27" and fits in the Mameroom cabinet?
It's hard to find CRT monitors that big nowaday since they are all widescreen and lcd!
Any help is appreciated! Thanks!
Numbski
  • Last login:November 03, 2020, 01:51:50 pm
    • Numbski
Re: Largest Mameroom PC Monitor Which Will Fit?
« Reply #1 on: October 11, 2008, 09:42:10 pm »
If you're stateside, hunt down any "Computer Renaissance" stores - they stock old, refurb computer gear.  I've seen some pretty mammoth 800x600 vga monitors flow in and out of those places.  That, and EPC -
http://www.epcusa.com
Build a man a fire, keep him warm for the night.
Set a man on fire, keep him warm for the rest of his life.
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
« Reply #2 on: October 11, 2008, 09:49:18 pm »
Here ya go.
http://www.happcontrols.com/monitors/49271700.htm
Or you could get one of these:
http://salestores.com/zenithh2.html
Or use a 27" CRT HDTV like this one:
http://www.google.com/products/catalog?q=27%22+crt+hdtv+samsung&oe=utf-8&cid=1529943829255572711#ps-tech-specs
If I had the space I'd go with the first option myself.
« Last Edit: October 11, 2008, 09:57:46 pm by Todd H »
Charles4400
« Reply #3 on: October 11, 2008, 10:17:21 pm »
Hey thanks for the links! Will definately check em out....
I also found that NEC MultiSync XM29 is supposed to be really good to use but IMPOSSIBLE to find (at least in my area...Los Angeles)
And yeah that MakVision looks good!  ;D
If any of you are familiar with the NEC XM29 (in case one miraculously appears)... do you think that's better than the MakVision?
Todd H
  • It's Gameday!
« Reply #4 on: October 11, 2008, 10:24:40 pm »
I know this guy is using the Makvision for his project and really seems to like it:
http://forum.arcadecontrols.com/index.php?topic=82241.0
You may want to ask him for some info about it.
Jack Burton
« Reply #5 on: October 11, 2008, 10:29:04 pm »
Do you plan on decasing the XM29 once you get it, cause it would be a nightmare if my XC37 is anything to go by.  There are four different motherboards plus like 3 more pieces of hardware inside.
In the case it should be perfect as long as it will fit in your cabinet.  I think Snaaaaake built a custom cabinet arund one.
Charles4400
« Reply #6 on: October 11, 2008, 11:09:37 pm »
Thanks Todd will check out that guys link....
Jack... IF (and thats a big if !) I do happen to get my hands on the NEC I don't think I will have to decase it, it should fit right in the mameroom cabinet.
Nec :Dimensions: 25" W x 18" D x 20.5" H
mameroom cab:
Monitor area width: 27"
Monitor area height: 24 13/16"
Monitor area depth: 20 7/16"
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #7 on: October 13, 2008, 09:17:41 am »
Did you say"big"... we do a 39" tri-res. But it is analogue. A friend of mine has one installed in a Dynam cabinet and is hoping to get mame running in the next wek or so. He is using a standard VGA card and leaving it at 640X480 (31Khz)
Rick@niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Charles4400
« Reply #8 on: October 13, 2008, 09:50:27 pm »
I said big Rickn not GINOURMOUS! LOL!
39" is HUGE and awesome!  I would love to see a mame cabinet with that bad boy in there....too big for my cabinet I'm sure but the fact that it exists is AWESOME!  8)
