Author Topic: Timer to turn the TV on ?  (Read 2327 times)
MarcC
  • Last login:February 22, 2010, 10:02:16 am
« on: October 07, 2008, 04:41:46 am »
Im just about to start building my 1st cab and have been purchasing all the required components etc.
The only thing left I have to solve is the TV in bios issue and how it would not display at 31khz (?)
I plan on having a totally enclose cab so I wont be able to turn the TV on and off, I plan to have it on standby all the time.
I also want it to have one button to turn everything on, I had a little idea!!
What about making a smaller timer curcuit so that the TV turns itself on after about 1 min or less?
Would this be possible? And if so could anyone desing me  the circuit please?
I have no elcetronice experience at all.
Kevin Mullins
    • Me on Myspace
Re: Timer to turn the TV on ?
« Reply #1 on: October 07, 2008, 11:19:04 am »
What operating system are you using ?
Can't you just use a NO GUI boot to not show the bios at bootup?
MarcC
« Reply #2 on: October 07, 2008, 03:57:26 pm »
Hi Kevin,
Thanks for y ou're reply.
I have solved this problem by doing the PCI gfx card trick, I managed to pick one up for £5 and it works perfect.
