Author Topic: OK to apply adhesive art directly onto metal cp or should i prime and paint ?  (Read 2439 times)
mrclean
    • Guscade
I have a control panel metal, removed the old artwork and i basically used my drill with a wire brush attachment to get the panel down to the shinny metal. Is it ok to apply my artwork directly to the metal, or should i prime and paint it ?
2,370,650 Gun.Smoke
Franco B
No need to prime.
somunny
  • Is it hot in here?
Yeah, I also think it would be best to apply it to the clean, bare metal.
TheShanMan
    • My Arcade (updated 1/30/13)
Scott from MameMarquees said otherwise to me. He said it's best to prime at the very least.
mrclean
    • Guscade
I don't mind in investing in a cheap can of primer, but I seem to have mixed feedback
2,370,650 Gun.Smoke
Franco B
I would definitely prime wood but not metal. As long as you get the CP nice and smooth I think you will get a much stronger bond CPO>CP than CPO>primer>CP. I imagine Scott knows what he is talking about but I wouldn't use primer personally.
wildbill
  • Last login:April 06, 2009, 12:54:23 pm
  • skate and create
Its best to at least prime it, because the metal is a little bit More porous and it doesn't give the sticker a good flat surface to adhere to. So I would prime then fine sand and clean then apply.
