Author Topic: Area 51 Power Problem  (Read 2591 times)
koinsatx
  • Last login:April 26, 2021, 11:46:31 am
« on: September 18, 2008, 06:46:40 pm »
I recently picked up an Area 51 working cabinet at an auction. It looks like it is a conversion and is in a Capcom dynamo cab which was originally a super street fighter II:new challengers cab (manual was inside).
Recently it has intermittently stopped powering up and I noticed several things, the power supply fan was not turning even though it did power up and an LED on the PCB call TOO LOW was red. I thought my power supply had died so I ordered a replacement power supply from Happ.
After swapping it out, everything seems to work fine but the TOO LOW LED is still lit.  Any one have any ideas?
Hope that all made sense as I am just getting started and trying to learn.
Kevin Mullins
    • Me on Myspace
Re: Area 51 Power Problem
« Reply #1 on: September 18, 2008, 09:36:47 pm »
Which power supply do you have ?
Does it have an adjustable 5v on it anywhere ?
koinsatx
« Reply #2 on: September 18, 2008, 10:07:52 pm »
I had replaced it with this one from Happ.
http://www.happcontrols.com/powersupplies/80001500.htm
Looking at power supply it does appear to have a "V adj" turn-screw on the side of case. I take it, that would be a voltage adjustment.
Man, I wish I remember some of my electronics classes from 20 years ago.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: September 19, 2008, 01:08:56 am »
That's it .....
Blanka
« Reply #4 on: September 19, 2008, 03:42:33 am »
Off Topic: Did Happ become Dutch? Suzo is Dutch, and they always say that a company with a double name will loose the second in a while. So Suzo must be the most important one here.
