Author Topic: Whiteside Slotting Cutter and Arbor  (Read 8273 times)
ratzz
« on: September 16, 2008, 08:51:54 pm »
Can someone please confirm the order my slotting cutter, washers, bearing and nut go in?
I have them set-up like this on my Arbor (top down):
Slotting cutter
Washer
Bearing
Washer
Nut
Is this correct?
Thanks guys  :cheers:
Benevolance
Re: Whiteside Slotting Cutter and Arbor
« Reply #1 on: September 16, 2008, 11:11:53 pm »
I had the bearing on top, and the slotting cutter blade in between the washers.
ratzz
« Reply #2 on: September 17, 2008, 08:34:49 am »
No problem guys, I set it up as I thought originally and had no problems.
Benevolance:
I *think* you may have had it installed incorrectly, but if it worked for you then great ...  :cheers:
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #3 on: September 17, 2008, 11:03:22 am »
I don't believe I put mine together.  I think it shipped assembled (though it was so long ago, perhaps I just don't remember assembling it).  Maybe I'll take a look at it when I get home.
Best Kid iPad Apps
Benevolance
« Reply #4 on: September 17, 2008, 11:25:03 am »
Mine was shipped with the washers, nut and bearing installed on the arbor. I just removed the nut from the bottom, slid off one washer, and added the slotting cutter to the mix. But hey! Whatever gets the job done, right? I still have all my fingers.  :)
ratzz
« Reply #5 on: September 17, 2008, 11:41:59 am »
Absolutely ...
I came across this (and a couple of other pictures like it) on the net, and figured this was the way to go ...
I also thought that the washers were in place to free up the bearing and allow a nice spacer for rotation.  :cheers:
« Last Edit: September 17, 2008, 11:43:41 am by ratzz »
shmokes
    • Jake Moses
« Reply #6 on: September 17, 2008, 12:16:05 pm »
Heh . . . I think wrong on so many levels.   ;D
Best Kid iPad Apps
« Reply #7 on: September 17, 2008, 01:06:50 pm »
But hey! On the other hand, I still have all my fingers.  :)
fixt
NelsonPJ
  • Last login:June 17, 2020, 06:50:27 am
« Reply #8 on: October 22, 2008, 06:42:11 pm »
Absolutely ...
Oops!  I just did the same thing myself!  I bought a Whiteside slot cutter and arbor at the local Woodcraft store and also apparently installed it backwards.  I simply removed the nut and washer, slid on the slot cutter, and replaced the washer and nut.  I didn't have any problems, but I've seen a few pictures around the web that indicates this is incorrect.
It appears the proper placement is to take everything off the arbor, then slide the slot cutter on first, then washer + bearing + washer + nut.  This way the bearing is the "lowest" point on the router bit when you're cutting the T-slot.
I got confused because I had just used a template cutting bit on my router in which the bearing was on "top" (because I was following a template that was on top of the plywood I was cutting).
I found another good image on Rockler's website:
Epyx
  • "You're an oddity"
« Reply #9 on: November 15, 2008, 04:00:26 pm »
This is great and seems to be correct based on my research. A few older posts show a different (and I think incorrect) order.
Last Project
Epyx Tutorials:
Tutorials
