Author Topic: what version of mame are you running and pc specs ?  (Read 4036 times)
daywane
  • Last login:September 01, 2026, 05:00:16 am
  • GRRRR!
« on: September 09, 2008, 10:28:07 pm »
I run version 36 on 300 to 500 meg PC's
version 56 on 700 to 1 gig pc"s
78 on any thing stronger than a 1 gig CPU
just wondering what every one else is running
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
Re: what version of mame are you running and pc specs ?
« Reply #1 on: September 09, 2008, 11:47:34 pm »
My gp2x handheld is running 035
My E6300 OC'd to 2.45ghz is running 127
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
protokatie
« Reply #2 on: September 10, 2008, 12:06:37 am »
MAME32 .120 on a 1.9 Ghz DualCore AMD with 2 Gigs of RAM.
gonzo90017
« Reply #3 on: September 10, 2008, 01:07:04 am »
Mame 0.36 on a 233mhz-550mhz. Fastmame 84 on a AMD Sempron 1.4ghz.
daywane
  • GRRRR!
« Reply #4 on: September 10, 2008, 04:35:40 pm »
does Mame use the DualCore?
protokatie
« Reply #5 on: September 12, 2008, 03:40:03 am »
Yes, it can be split into two threads, one for the general emulation, and the other for GFX emulation/rendering. Each thread will run on different cores.
« Last Edit: September 12, 2008, 03:44:04 am by protokatie »
ideft
  • Last login:February 11, 2012, 04:06:09 pm
  • "Mister, I suspect you to be a dope fiend"
« Reply #6 on: September 13, 2008, 12:28:53 am »
Mame .117 and FastMame .84 on a P4 2.0 512 sdram
« Reply #7 on: September 13, 2008, 04:31:32 am »
How is this achieved?  Is it automatic, or is there a setting somewhere?
I'm running .119 MAME (hacked for no nag screens and optimized for dual core AMD)   <---- is mine already set to be split by doing the hack?
Just curious...
protokatie
« Reply #8 on: September 15, 2008, 12:09:48 am »
Just curious...
In INI/Mame.ini, under "WINDOWS PERFORMANCE OPTIONS" set multithreading to 1.
EG
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            1
Is what it is in my Mame.ini file. (It is a selectable option in MAME32/UI from the user interface as well.)
« Reply #9 on: September 15, 2008, 02:18:26 pm »
Yeah, I had that enabled in my mame.ini file already.  So I guess I'm good to go.   ;D
P.S. - I'm running .119 on an AMD 4200+ dual core with 2GB RAM.  Originally I ran it on an AMD 4000+ chip and it still ran smoothly.  The extra +200 didn't really make any difference.  Either way, everything runs great.
« Last Edit: September 15, 2008, 05:28:54 pm by DeLuSioNal29 »
