Author Topic: Problems with Maximus Arcade - Can't exit games..  (Read 8091 times)
KeWLMoNk
  • Last login:September 06, 2008, 10:56:05 pm
« on: September 06, 2008, 03:15:26 pm »
Just wondering if anyone else has experienced this problem:
I built my cabinet over a year ago. For some reason I still can't exit games all of the time after playing for a short period of time.   The 'Exit Executable' button I assign just doesn't work, on my X-Arcade Tankstick or on the Keyboard itself (i had it as the letter B, or a button my X-Arcade, and I also tried 2 buttons together on the X-Arcade, one of each players side..nothing worked).
 It's very frustrating to have to ALT-CTRL-DEL to get out of a game, and reboot the system every time o(since the X-Arcade stick doesn't respond correctly after Alt+Ctl-Del and closing it) - My friends and family are pretty much stuck playing 1 game at a time.
Is anyone else having this problem? It's hard to believe my system can't handle the programs as I'm running a P4 3.2ghz with 2GB RAM, Win XP SP2, and an X-ARCADE Tankstick.
I really don't want to use a different front end as this one is by far and away my favorite. I hope someone out there can help.
Just as a side note - I took my Tankstick out a few nights ago to test a theory that MA and X-Arcade sticks may have a compatibility problem and sure enough I was able to exit games without any issues.     It sounds like a problem with X-Arcade Tanksticks (or regular sticks too maybe) and MA but I'd like to try and verify this problem with others.
Miguelsluma
  • Last login:June 11, 2010, 10:20:02 am
Re: Problems with Maximus Arcade - Can't exit games..
« Reply #1 on: September 06, 2008, 03:45:28 pm »
Not sure if this contains any help, but theres some exit troubleshooting on the maximus website.
If this doesnt help i am sure someone at the forum there would be able to help you out!
http://www.maximusarcade.com/phpBB2/viewtopic.php?t=825
edit: Found another person with a problem with the x-arcade together with MA, but found out you already replied to that topic saying it wasnt the anwser for you...  Perhaps a PM with your problem to mameseer at the maximus arcade forum would give you some new hints. good luck
« Last Edit: September 06, 2008, 03:52:13 pm by Miguelsluma »
KeWLMoNk
« Reply #2 on: September 06, 2008, 06:05:01 pm »
thanks for the reply - yea I'm on the MA forums too I just figured I'd post here too to see if anyone else is having this problem - so far it looks like a pretty big bug in MA so my fingers are crossed that mameseer can figure it out and fix it  :)
studmuff
  • Last login:September 30, 2012, 09:40:15 pm
« Reply #3 on: September 07, 2008, 09:22:03 pm »
Have you tried configuring it to exit emulator with 2 buttons?  Istead of end or escape, try configuring the exit button so that when you hit player 1 and player 2 buttons at the same time it exits out of emulator back to MA.
Encryptor
  • Trade Count: (+34)
« Reply #4 on: September 08, 2008, 10:49:06 pm »
I have a similar problem but mine is only with pc games. If I use the Exit/Quit button inside the pc game it exits the game but leaves me in a black screen. I then have to hit the exit executable key sequence that I have set up in MA. As far as MAME I don't have any issues exiting out of them back to MA.
Try to set your exit game key to use "End" to exit games. It's a work around I got from Delusional at the MA forums. As long as I exit a pc game using that key and not the Exit button in the game it works fine. Try it and let us know if that works.
Encryptor
Trebeck
  • "The Arcade" - Build #4
« Reply #5 on: September 09, 2008, 04:55:31 pm »
I have this too sometimes with Genesis for some reason.  I have to hit exit, wait a sec, then hit it again and that will do it.  If I find out why I'll post it.
