Author Topic: will installing an older video card on a new mobo degrade graphic power?  (Read 1972 times)
swaffar
ok first of all i just wanted to explain that i'm building a coffee table top control panel for two with all the bells and whistles.  i'm mounting a PC inside of it.  in an attempt to save some cash i went with an ok mobo:
XFX MG-61Mi-7059 Motherboard - nForce 610i/7050, Socket 775, MicroATX
with an Intel Celeron Dual Core E1200 1.6Ghz 512K 800Mhz FBS, and Patriot 2048MB PC5400 DDR2 667MHz.
Since the idea behind my panel is to be an arcade in a box and somewhat portable i wanted to make sure it would hook up to any kind of tv.  i decided to drop $25 on a EVGA GeForce FX 5200 Video Card - 128MB DDR, PCI, DVI, S-Video TV Out card.  So now i should be good for VGA, DVI/HDI, and S-Video...
Now that is inferior to my on board video correct?  So by installing this card will the on board power be useless or will i simply gain the DVI, S-Vid output without sacrificing graphic power?
thanks for any help guys.
« Last Edit: September 05, 2008, 07:48:11 am by swaffar »
My projects:
Re: will installing an older video card on a new mobo degrade graphic power?
« Reply #1 on: September 05, 2008, 02:16:00 pm »
if you use the $25 card, then youre using the $25 card and NOT the  onboard at all
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
« Reply #2 on: September 05, 2008, 04:43:58 pm »
Also, if your main intention is mame, you're going to be fine anyway for the vast majority of the games already with either video choice.
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
swaffar
« Reply #3 on: September 05, 2008, 07:14:22 pm »
yes... mame, old consoles, laserdisc games, visual pinabll... too bad future pinball isn't an option, but i'm pretty sure it wouldn't fare very well with the onboard either.  sheesh that app runs slow on my desktop
My projects:
moose
  • Last login:June 27, 2010, 03:03:14 am
« Reply #4 on: September 05, 2008, 09:11:24 pm »
Basically any game up to and including Unreal Tournament(1999) will play with no problems at all. Everyone's already said you'll be using the 25$ card only, but unless you're going to start playing quake4 or something, you won't have anything to worry about.
