Author Topic: Need help with windows 98 resolution? mebay video card trouble?  (Read 2511 times)
emopants92
  • Last login:July 18, 2010, 02:36:30 pm
  • I am Sparkles, And I am obber SCARY!
Ok I have an old compaq 5000us computer, with a 3DFX 210-0364-003 vga card. Ok I got the lastest driver and installed it on the computer, but still under device mangement it says pci card under other hardware with a yellow question mark. It used to only be 16 colors and 2 colors now it has the Medium (16 bit) and the 256 colors and, ect... BUT the reslolution is stuck at 640 X 480( I think that was the setting not entirely sure)?
Some times every one needs a good scare, Take (S)'Care
ahofle
    • Arcade Ambience Project
Re: Need help with windows 98 resolution? mebay video card trouble?
« Reply #1 on: August 25, 2008, 06:20:30 pm »
Sounds like the driver isn't the correct one.  You will be stuck in VGA mode until you find the correct driver and the yellow exclamation mark goes away unfortunately.
emopants92
« Reply #2 on: August 25, 2008, 09:11:03 pm »
I have tried tons of them they are all the same and dont do it?
northerngames
  • Trade Count: (+18)
« Reply #3 on: August 26, 2008, 12:05:57 pm »
try to disbale it in windows device manager and then delete it afterwards.
if you have a windows 98 disk put it in and try to update the drivers off the disk if possible is another thing you could try.
it also may be set to your primary display under your bios setting instead of having it set to the vga for primary.
if all else fails try the quikres utilty to force the res onto windows.
Ummon
  • Trade Count: (+13)
« Reply #4 on: August 26, 2008, 04:50:41 pm »
Also, some people over at Mameworld might better know what drivers will work with that old card.
Yo. Chocolate.
Stephen Hawking
emopants92
« Reply #5 on: August 30, 2008, 05:29:53 pm »
Sorry been really busy For some reason I restarted the computer a million times, but I just went and turned it on from about of a week that wasnt running and It found the driver at start up and is fine now? so idk it works now
Ummon
« Reply #6 on: August 30, 2008, 06:39:48 pm »
Good. Windows is finicky that way. I've experienced similar.
Yo. Chocolate.
Stephen Hawking
