Author Topic: Hantarex mtc28EQ2 input configuration  (Read 2289 times)
imtapha
  • Last login:December 24, 2024, 11:09:27 am
« on: August 20, 2008, 02:27:57 pm »
Hi. I have an Alpine ski 2 which has a 28inch hantarex polo that has died. I have a nos Hanterax mtc28EQ2 which has a variety of input possibilities on D-type, scart and s-video. would it be possible to wire this to my Alpine 2 and if so how? hope someone can help. pic of mtc28 below
grantspain
Re: Hantarex mtc28EQ2 input configuration
« Reply #1 on: August 20, 2008, 03:01:34 pm »
you can use the scart,
there is a thread at the top of the monitor page
imtapha
« Reply #2 on: September 04, 2008, 11:32:09 am »
have tried using the scart wired 4 rgb and although there is an image on screen the colours are very pale and the image has a shadow and is not very well defined. does anyone have any ideas?
grantspain
« Reply #3 on: September 04, 2008, 03:01:59 pm »
you need more than 4 wires if using the scart,follow the instructions on the thread
imtapha
« Reply #4 on: September 05, 2008, 02:52:38 am »
sorry for the confusion was being lazy wired 4 scart didnt mean 4 wires should have said wired for scart. i did follow instructions in thread and ended up with fault described
grantspain
« Reply #5 on: September 05, 2008, 06:19:30 pm »
do you have an impedence switch,maybe marked 1v or 0.75
imtapha
« Reply #6 on: September 06, 2008, 03:10:17 am »
no impedence switch
grantspain
« Reply #7 on: September 06, 2008, 04:41:37 am »
maybe try the rgb d plug,i know the tech at hantarex very well so if you wish i can ask him the pinout of that plug
i will call him on tuesday as i am off work until then
imtapha
« Reply #8 on: September 06, 2008, 05:00:23 am »
that would be great many thanks
imtapha
« Reply #9 on: September 29, 2008, 12:09:18 pm »
hi bog trotter any joy with pin outs on the d type vga input
grantspain
« Reply #10 on: September 29, 2008, 01:42:54 pm »
sorry mate i had completely forgot,will do tomorrow
grantspain
« Reply #11 on: October 01, 2008, 05:50:58 am »
o.k there are 2 versions of this,1 for the u.s market and 1 for europe
europe pinout
1-ground
2-n/c
3-red
4-green
5-blue
6-n/c
7-n/c
8-horizontal(comp) sync
9-vertical sync
u.s version
1-ground
2-comp sync
3-blue
4-green
5-red
6,7,8,9-ground
