Author Topic: Arcade Addiction Marquee  (Read 3365 times)
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« on: August 18, 2008, 09:36:41 am »
So here's the marquee I've designed for my cab. I don't have any real artistic talent, so I decided to go with a simple idea - create an epic battle between a bunch of classic games. I've always been a fan of William stuff, so most of their classics are represented. All in all, there are objects from 13 different games - mostly space themed.
To create the objects "game characters", I used mame screen captures, then increased the resolution to 300dpi and enlarged about 1000%. For each game I created a palette of objects - if anyone is interested in these, I could post the Photoshop files.
For the battle, I played with scale a bit, and mixed everything up. My family got a kick out of guessing which characters came from which games and what was wrong.
All in all, it's a bit busy, but I like it.
« Last Edit: August 18, 2008, 10:00:28 am by arzoo »
Robots will kill you.
Arcade Addiction
xhiltonx
  • Last login:August 28, 2008, 03:01:34 pm
  • Zombies ate my neighbours
Re: Arcade Addiction Marquee
« Reply #1 on: August 18, 2008, 01:17:47 pm »
nice:::::nice work, keep it up. :applaud:
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #2 on: August 18, 2008, 05:47:19 pm »
I like it!
Ortizimo
  • Last login:July 10, 2024, 07:26:45 pm
  • USAF Retired Veteran (1995-2015)
« Reply #3 on: August 23, 2008, 11:02:49 am »
looks awesome...love the all around retro look.
Sometimes, when it's quiet, I can still hear the monkeys." - Guybrush Threepwood, Mighty Pirate.
cmoses
« Reply #4 on: August 26, 2008, 04:30:31 pm »
I like it alot.  Can you explain your process of capturing the images a bit more.  I am looking to get some pixel images for my own project and am having a hard time getting pixel pictures from some games I want.  I have not used MAME to capture images so I am not familiar with the process.  I think I can do something similar to what you did to get the type of images I am looking for.
arzoo
    • LEDBlinky
« Reply #5 on: August 30, 2008, 10:07:41 am »
I'm not a Photoshop expert and there may be a better way - but here's how I did it. From mame, use F12 to do the screen caps. The files end up in the snap folder. They are very low res. I opened the .png files in Photoshop, then used the "Image Resize" function to change the resolution to 300dpi and increase the image size - the trick here is to make sure the "Resample Image" value is set to "Nearest Neighbor". That's it.
Arcade Addiction
