Author Topic: Sanyo EV-20 as a monitor for Supergun?  (Read 2071 times)
shilmover
  • Last login:September 25, 2018, 12:36:59 am
« on: August 15, 2008, 10:30:15 am »
I built a supergun to test out the large pile of boards that I have.
I hooked up a Sanyo EV20 (since I have several).
Some of my JAMMA boards display fine, but many (including ones that I believe are good) are displaying garbled.  if I push the test button or coin buttons, the screen changes (but remains garbled).
Could this be a resolution problem or a sync problem?
Can I hook up a regular monitor to a supergun if I hook up the the wires correctly to the VGA connector?
My projects...
Finished:  Stargate (only 'cause I got it that way)
In progress:  Tron, 48-in-1 for School Auction, DKJr (currently a 60-in-1), Millipede, MAME System
SirPeale
  • Green Mountain Man
Re: Sanyo EV-20 as a monitor for Supergun?
« Reply #1 on: August 15, 2008, 10:36:51 am »
Likely you just have to adjust the sync.  This is normal if you're changing boards.
shilmover
« Reply #2 on: August 15, 2008, 10:57:23 am »
I had tried that, but no change...
Barry
My projects...
shilmover
« Reply #3 on: August 15, 2008, 12:06:14 pm »
I have been adjusting the pots on the back board, but I dont think one of those is the sync.  Does anyone have a manual for this monitor or know where the sync pots are?
My projects...
Kevin Mullins
    • Me on Myspace
« Reply #4 on: August 16, 2008, 10:04:19 am »
Manual - Sanyo 20EZ
A sync issue should have fairly distinct horizontal/diagonal lines making up the image ..... what does your "garbled" picture look like ? (can you get a pic)
shilmover
« Reply #5 on: August 16, 2008, 10:13:41 pm »
Thanks for the manual.
I plugged in one of the other monitors I had (a Sharp).  It works great and actually has a switch to invert the video.  :)
I will plug the other one in and get a pic posted.
My projects...
