Author Topic: 25" TV vs 21" monitor  (Read 2248 times)
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
« on: June 09, 2003, 10:37:05 am »
Hi there,
I wanted to know which is the better way to go TV on pc monitor, because I just can't seem to make up my mind up on this one!
Also with a TV using s-video what is the maximum resolution you can display on the TV and how to pc games look compared to a monitor.
Thank you
Gary
ahofle
    • Arcade Ambience Project
Re:25" TV vs 21" monitor
« Reply #1 on: June 09, 2003, 11:28:44 am »
Well I'm certainly no expert on the subject, but I recently had the exact same dilema as you (I'm in the process of building my first cabinet).  A friend of mine had MAME running with S-Video hookup to a TV so I went over to check it out.  After trying several different games, my mind was made up -- go with the TV.  The picture is much more like the original games were.  Plus you get an extra 4-5 inches and it costs less money.
I believe he was running windows at 640x480 and while it may not have been the crispest picture, it was certainly much better than I expected.  Even games with bizarre resolutions like Toobin played fine.  I also imagine PC games would run fine at that resolution (didn't try it though), although I personally prefer at least 800x600 for first person shooter games.  Another benefit with TV is that console emulators look absolutely incredible on a TV -- he hooked up his NES and Sega emulators and I was sold.
The only problem I found was finding a TV around that size with S-Video that would fit in my cabinet!
IIOIOOIOO
  • Last login:August 04, 2003, 02:18:12 pm
« Reply #2 on: June 09, 2003, 01:06:26 pm »
That's why you always these the monstrous obscenities like the Mameroom cabinet$ that only  barely resemble an actual arcade cabinet.
Apollo
    • Eight Bells
« Reply #3 on: June 11, 2003, 05:25:13 pm »
Best choice is arcade monitor lol.
IIOIOOIOO
« Reply #4 on: June 11, 2003, 05:27:47 pm »
Get an Eygo, and get the best of both worlds.
Ghoward
  • Mame rocks!!
« Reply #5 on: June 12, 2003, 02:59:09 pm »
I've made my mind up at last it's just going to have to be a WG 9200 27" , there are too few 25" tv's with S-video and a 21" pc monitor is just too small.
On the other hand the WG 9200 will fit in just right.
Gary
