Author Topic: Mame32 problems  (Read 2039 times)
starbug1234
  • Last login:August 03, 2004, 10:29:44 am
  • I'm a newbie, pls be kind!
Mame32 problems
« on: June 09, 2003, 06:34:48 am »
Hi,
Hope some one here can help. I have built a fresh install of Windows
2000, using a via epia 800 mini itx motherboard, and using th elatest
ver of mame32.
When I select a ROM to play, the screen blanks, then seconds after
the Mame gui comes back. I have no idea why this is doing this.
I have tried changing all the display options to no avail.
Any advice appreciated.
Regards
Stuart
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
Re:Mame32 problems
« Reply #1 on: June 10, 2003, 12:59:53 am »
Hi,
ver of mame32.
Regards
Stuart
Make sure you have your directories specified correctly in mame32.  Also make sure you have the correct romsets for the version of mame32 you are using.
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
starbug1234
Re:Mame32 problems
« Reply #2 on: June 10, 2003, 04:17:38 am »
Have tried this, all correct.
S.
buck3480
  • Last login:August 28, 2007, 03:41:14 pm
  • I'm a newbie
Re:Mame32 problems
« Reply #3 on: June 11, 2003, 09:20:51 am »
This is my first post, so I wanted to take a second to say thanks to everyone who keep this site up.  I'm building my first cabinet as we speak, and I've learned so much here. Thanks...
Having said that, I'm having the same problem that Starbug is having.  Any suggestions would be appreciated.
BobA
  • What Me Worry?
Re:Mame32 problems
« Reply #4 on: June 11, 2003, 09:41:17 am »
Is anything in Mame32 working correctly?  For example are you getting title displays or snaps or marquess showing?    When you set the directory paths did you just leave the default roms or is your actual path eg c:/mame/roms showing where you set it?   Do you have all the roms req to play the game?   Do you have the parent rom for the game you are trying to play?  Do you have the bios rom if the game requires it?
Most importantly make sure your path to the roms directory shows where you set the directorys in mame32 - Options - directories.
BobA
