Author Topic: quick question about happ vision pro 19" installation  (Read 2865 times)
patchboston
  • Last login:September 02, 2020, 09:31:04 am
« on: August 06, 2008, 11:41:35 pm »
*I posted this in my restoration thread, but I believe I'll get better responses here (seems more appropriate)*
my jamma board has the the standard vide wires of: r,g,b, gnd and sync. (bob roberts)
where as the chassis has:
*connector 1*
r,g,b, gnd, vert-sync, horizontal-sync.
I was thinking I'd just plug the color coded connectors to their according chassis wires. White to white (h-sync) gnd to black, etc. Good.
here is where I'm confused:
The final wire, vert sync, which is yellow. Do I leave this alone? Or do I hook it up somewhere else.
Theres also another set of 3 pinouts containing another set of v-sync, h-snc, and gnd. No connector though. Whats the deal with these?
heres my new monitor: http://happ.com/monitors/49132900.htm
Own: Pac-man, TMNT, P.O.W.
grantspain
  • Last login:September 02, 2026, 04:45:02 am
Re: quick question about happ vision pro 19" installation
« Reply #1 on: August 07, 2008, 06:51:32 am »
leave the vert sync off for the time being as you probably will not use it
the other plug,dunno could be positive sync signals-don't worry about it
do you have manual for the monitor?
patchboston
« Reply #2 on: August 07, 2008, 07:40:44 am »
Grantspain,
heres a link to the manual: http://happ.com/images/pdf/49-1329-VP2_manual.pdf
Whats the difference between vertical sync and horizontal sync?
Is horizontal the standard?
This is going in a pac-man and will be orientated vertically. Does that make a difference? hah.
sorry if these seem like ignorant questions, but I'm brainless on the subject  :banghead:
I checked the faq, but didn't see anything about v-sync or h-sync that pertained to my needs.
« Last Edit: August 07, 2008, 07:43:25 am by patchboston »
grantspain
« Reply #3 on: August 07, 2008, 05:45:49 pm »
o.k normally most older game boards output a negative horizontal sync to lock the picture so in relation to this all you need to connect is the horizontal sync wire
this is not always the case and different monitors like different syncs,some namco boards actually have to have the vertical sync connected and linked to ground via 5k resistor
but tbh i am 100% sure if you connect your horizontal sync wire it will work,if it don't then you will cause no damage whatsoever and you can try some other options
patchboston
« Reply #4 on: August 07, 2008, 06:05:10 pm »
 I made a mistake-- Its a vertical pac-man cabinet, but it will be using a 60-in-1.
Eventually I'd like to return it to a dedicated pac, so I do appreciate the heads up.
also thanks for letting me know about not damaging the board.
 I'll start with the basic setup and go from there!
« Last Edit: August 07, 2008, 06:23:34 pm by patchboston »
patchboston
« Reply #5 on: August 07, 2008, 11:51:27 pm »
Thank you for your help!
I just finished installing all the wires into molex connectors  >:D
(note: klax is the only pcb I have handy right now.)
« Last Edit: August 07, 2008, 11:53:32 pm by patchboston »
