Author Topic: Video Card PROBLEM.....HELP PLEASE !!!!  (Read 2910 times)
MAME nut
  • Last login:March 18, 2024, 12:33:01 am
« on: August 05, 2008, 11:15:09 pm »
I have an old Compaq computer (PIII ??) that I picked up at a Rummage Sale recently.  It had Windows 2000 on it, but I chose to put Windows 98 on it instead....like my other MAME cabinets.  After the Win98 install, the monitor ended up only being 16 color....which won't let me run MAME.  (The original video card drivers were erased and Win98 chose the wrong driver for the Dell monitor I'm using.)
My problem.....I don't know what driver I need.  I went the www.hp.com website and downloaded several drivers, but nothing works.   :banghead:  ANY IDEAS??!?!
Thanks,
MAME Nut
SirPeale
  • Green Mountain Man
Re: Video Card PROBLEM.....HELP PLEASE !!!!
« Reply #1 on: August 06, 2008, 04:34:11 am »
Crack it open and see what's inside.
Kevin Mullins
    • Me on Myspace
« Reply #2 on: August 06, 2008, 02:32:27 pm »
It's not the monitor you need drivers for..... it's the video card chipset you need drivers for.
I'm assuming this PC has onboard video that you are trying to use ?
Any idea what model of Compaq that unit is?
Or what motherboard it has?
MAME nut
« Reply #3 on: August 07, 2008, 04:45:57 pm »
Sorry.....not sure where to look for the Video Card.  I can't find a model number anywhere, only a S/N number.
Can you tell me what to look for??  Or, should I post a picture??
Thanks,
MameNut
SirPeale
« Reply #4 on: August 07, 2008, 04:50:13 pm »
You have to open it up.  Look for the card that your monitor plugs into.  That's your video card.
If it's on the motherboard itself, check out and see if there are any identifying marks on it silkscreened somewhere.
MAME nut
« Reply #5 on: August 07, 2008, 06:05:45 pm »
Pearle,
It is opened.  I just can't ID the video card.  I put a card in about 10 years ago...and it was a "card".  This does not appear to have a card.
See pictures below.
SirPeale
« Reply #6 on: August 07, 2008, 07:35:11 pm »
Who the heck is Pearle?
You have an onboard chipset.  I can see one of them (the southbridge I think) and it's an Intel chip.  I don't know what the northbridge is (it's covered by the green heatsink), but there's a good bet it's an Intel one as well.
If this was made by a major manufacturer (Dell, Compaq) what's the model number?
Carlito
  • Last login:July 14, 2021, 01:31:51 pm
« Reply #7 on: August 07, 2008, 09:53:12 pm »
northerngames
  • Trade Count: (+18)
« Reply #8 on: August 08, 2008, 12:02:19 pm »
there should be a board number in white on the motherboard write down those numbers and letters and do a google search and your board should show.
once you find what board it is do another google search for the motherboard drivers.
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
« Reply #9 on: August 11, 2008, 08:05:12 pm »
Which games do you think you'll play the most on this computer?
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
MAME nut
Re: Video Card PROBLEM solved!!!.....sound problems now HELP PLEASE !!!!
« Reply #10 on: August 23, 2008, 04:47:14 pm »
Sorry Peale.......not sure where the heck that came from!!  It an old Compaq machine....but I can't find any model numbers on it.
Carlito....I used your link for a driver and it works now....THANKS!!!!
BUT.....I have NO SOUND.....anyone have a link for the correct sound driver??  Would it be with the 815e chipset drivers??
Thanks,
MAME nut
SirPeale
« Reply #11 on: August 23, 2008, 09:37:31 pm »
I doubt it.  It's likely one of the other chips on the motherboard.  I can't see it clearly enough to make it out.  It should stand out as one of the major (usually) sound chip manufacturers.  ESS is one such manufacturer, Yamaha is another.  So is Creative Labs.
Kevin Mullins
    • Me on Myspace
« Reply #12 on: August 24, 2008, 01:41:10 am »
I'm guessing from a little research that the mother board is from a Evo D300v or similar model.
So try these drivers for your audio:
AC97 Audio Drivers
Main List of Drivers for that model:
Ala Carte Drivers
Let us know how it goes.
