Author Topic: MameWah help. When go to a game it goes to mame menu screen?  (Read 2576 times)
emopants92
  • Last login:July 18, 2010, 02:36:30 pm
  • I am Sparkles, And I am obber SCARY!
« on: August 04, 2008, 08:48:42 pm »
Ok I am using mamewah fe with mame commandline. And everytime I click the rom on the mamewah screen it goes to the select a game screen on mame. How do I get the game to run not the menu screen in mame?
Some times every one needs a good scare, Take (S)'Care
Re: MameWah help. When go to a game it goes to mame menu screen?
« Reply #1 on: August 05, 2008, 03:58:34 pm »
Sounds like it is not running the correct commandline (or romname) for some reason.  Have a look in mamewah.log and see what is going on...post it here if you need a hand.
emopants92
« Reply #2 on: August 05, 2008, 11:49:49 pm »
I have bolded what I think is the part thats having some kind of error sending me to my mame menu.
8/5/2008 3:53:30 PM MAMEWAH v1.63 launched
8/5/2008 3:53:30 PM Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
8/5/2008 3:53:30 PM Desktop colour: 9981440
8/5/2008 3:53:30 PM Wallpaper filename:
8/5/2008 3:53:30 PM Desktop display mode: 800x600 @ 60Hz, 16bit colour
8/5/2008 3:53:30 PM Decimal symbol: '.'
8/5/2008 3:53:31 PM Games list read: mame-0.lst
8/5/2008 3:53:33 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
8/5/2008 3:53:33 PM Layout selected: C:\Documents and Settings\ArcadeCabinet\Desktop\MameWah\config\mame\\layout.lay
8/5/2008 3:53:34 PM No. joystick devices attached: 0
8/5/2008 3:53:34 PM Ctrlr file selected: C:\Documents and Settings\ArcadeCabinet\Desktop\MameWah\config\mamewah.cfg
8/5/2008 3:53:34 PM Keyboard enabled
8/5/2008 3:53:36 PM Current drive/directory selected: C:\Arcade\Mame
8/5/2008 3:53:36 PM Commandline run: C:\Arcade\Mame\mame.exe {flags=210}
8/5/2008 3:54:13 PM Application quit: C:\Arcade\Mame\mame.exe
8/5/2008 3:54:13 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
8/5/2008 3:54:14 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
8/5/2008 3:54:18 PM Mode 800 x 600 @ 60Hz, 16bit colour selected after 1 attempt(s) at 1/2 second intervals.
8/5/2008 3:54:24 PM MAMEWAH quit
« Reply #3 on: August 06, 2008, 07:26:30 am »
You are right, this line indicates no rom name is being sent.
The default \config\mame\mame.ini file is preset to an extend, but the relevant line should look as follows:
emulator_commandline                      c:\arcade\mame\mame.exe [name]{nodosbox}{nosafelaunch}
emopants92
« Reply #4 on: August 06, 2008, 11:48:28 am »
YEAH! I found out that I had {noodoslaunch} so I fixed the extra O part and everything is ok! OH one quick question I have a very old computer that orignally had windows me on it. It has 64 mb of ram and a Nvidia TNT 2 graphics card. And noticed that on some games like Donkey Kong, The sound has a skipping and echo effect. How do I fix that, Is it because my ram is to low and its having trouble with the frame rate because I was conisidering puting in 512 mb more into the ram?
« Last Edit: August 06, 2008, 11:50:22 am by emopants92 »
gonzo90017
« Reply #5 on: August 06, 2008, 12:46:04 pm »
Might be your processor. Try using an older version of Mame. Like mame 0.55.
emopants92
« Reply #6 on: August 07, 2008, 04:08:58 pm »
Yes that fixed thanks, i tried .55 but couldnt get it to work with mamewah. So I tried mame.103 and it works thanks.
