Author Topic: Grid wars and quantasm running slow  (Read 2427 times)
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« on: August 03, 2008, 01:09:09 pm »
My mame pc consist of a P4 2.2 ghz with 1 gig of ram and a ATI 9600xt vid card that should be a 120mb vid card. This pc is also running Tinyxp. For a display I'm using a 20" gutted tv tube.
For some reason no matter what I do these two games run like dog poo. The cpu is only using at the most 50% while these games are going.
I have another pc with about the same specs and full xp version that had this video card in it and these games ran fine, with a lcd monitor.
Could the tinyxp have something to do with this issue?
thanks
Space Fractal
  • Space Fractal
    • Space Fractal
Re: Grid wars and quantasm running slow
« Reply #1 on: August 03, 2008, 02:10:28 pm »
Do use the gridwars 2 patch I created in the past (Im are NOT the original author of Grid Wars, I just modifed the source to became a more cab freindly patch)?
http://forum.arcadecontrols.com/index.php?topic=80123.0
I mean this slowless is due the desktop is set to 16bit, but should set that to 32bit. A Another user have that problem and fixed after changing his desktop to 32bit.
Remember to update all drivers as well.
Grid Wars is a OpenGL application, not DirectX since BLitzmax DirectX drivers is much slowere than OpenGL.
Both games is single threaded applcation, and your CPU is a a HyperThreading CPU, hence Windows see your processor as 2 seperate CPU's. Hence 50%.
« Last Edit: August 03, 2008, 02:14:25 pm by Space Fractal »
BORIStheBLADE
« Reply #2 on: August 03, 2008, 02:14:24 pm »
In the control panel for the display it was set to 32bit. Thats what you were talking about right?
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #3 on: August 03, 2008, 02:21:02 pm »
Yes. It might been a TinyXP issue, but I known nothing about it. You might have disabled a service needed by games and mightbeen have used software render. I do not known.
So all I can see is try to update your graphics drivers and your motherboard drivers.
mmalficia
  • Last login:November 29, 2009, 03:11:37 pm
« Reply #4 on: August 03, 2008, 02:41:39 pm »
noticed you have a ati card  one thing to try  google up ati tools  and driver cleaner    then instal thier   driver pack for  your card   not the  official ones  ..     mainly  it has better opengl support and youll be sure   the driver  was  cleaned out before  installing the new pack  ..
on a side note  not sure about  tiny xp    but alot of the xp builds with direct x streamlined into the instal can actualy be a major pain to update  for some reason  youll get partial updates    best aproach is  to  boot your system into safe mode  set your vidio driver  to vga   reboot  run the ati removal tool  and dirext  x  tools  make sure  everythings gone   then  reinstal what you need..
mmal
BORIStheBLADE
« Reply #5 on: August 03, 2008, 08:18:34 pm »
So i changed the driver and it works!
thanks guys
Space Fractal- I'm going to check out your patch now, thanks
« Last Edit: August 03, 2008, 08:21:22 pm by BORIStheBLADE »
