Author Topic: Newer Mame older roms  (Read 957 times)
beerbarrel
  • Last login:April 17, 2025, 03:04:00 pm
« on: July 27, 2008, 10:57:05 pm »
Curious question....
I just started building my cab. I was setting up my computer and everything went well. I set up maximus arcade with no big issues. I dl a couple of roms to try it out and things went well. I was looking around in some old software that I had and found a DVD full of mame roms. I loaded them on the HD thinking that they would work fine. I wouls say at least half won't run. Are there issues using older roms with a new version of mame?
Thanks,
Tracy
jardine
  • Last login:May 12, 2025, 05:09:12 am
Re: Newer Mame older roms
« Reply #1 on: July 28, 2008, 12:07:43 am »
Short answer - YES
Long answer - If you use clrmamepro it should help you find the roms with errors. Hope this helps.
gonzo90017
« Reply #2 on: July 28, 2008, 01:34:12 am »
Or you could use the Mame version as your roms.
