Author Topic: Adding coin door, In MAME can i have it use 5,6 and 2 other keys as "coin 1 / 2"  (Read 1419 times)
mrclean
    • Guscade
on the side of my current MAME Cab I have 2 "pinball buttons", which also double as Coin 1, and Coin 2  keys 5 and 6 etc.. is there any way I can have other "keys" in addition to 5 & 6 function as my add coin buttons ? I have an IDE Cable hooked up into a mini pac, and while testing the free wires that arent being utilized with ultimarcs winipac i have about litterally 7 free keys.. such as : "r" etc..
2,370,650 Gun.Smoke
Ginsu Victim
  • Last login:May 11, 2026, 06:06:32 pm
  • Comanche, OK -- USA
Just going into the button setup in MAME and select COIN 1 and press the button you want, then select it again without moving off of it, and press the switch on the coin mech. Then do the same for COIN 2.
Hope that was clear enough.
Check out my first product, The Tone Ledger, a premium workflow tool designed for guitarists, bassists, keyboardists...pretty much anyone who enjoys using amps and pedals.
