Author Topic: Coin Door - Coin reject lamp voltage?  (Read 1456 times)
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
« on: July 23, 2008, 12:24:00 pm »
Does anyone know the proper voltage for this coin door (coin reject lights) from Happ?  ???
http://www.happ.com/coindoors/40000800.htm
I would imagine that it's a "standard".  I've got 5 and 12 volts available... I just don't want to put 12v across a 5v lamp.
tkx!
... Why is it that you always find it in the last place that you look? ...
SirPeale
  • Green Mountain Man
Re: Coin Door - Coin reject lamp voltage?
« Reply #1 on: July 23, 2008, 01:25:45 pm »
It depends on the bulb that's in there.  You can always change it to whatever you want.
paulscade
« Reply #2 on: July 23, 2008, 05:44:44 pm »
Yea... I've looked at the bulb.  The only markings on it are:
VCH
161
and
717
Google didn't turn up much with only this info.
I figured that this would be a "standard" coin door that plugged into some "standard" harness... so it would likely have a "standard" voltage.... that you guys would know.
paulscade
« Reply #3 on: July 23, 2008, 06:08:02 pm »
It looks like this:
SirPeale
« Reply #4 on: July 23, 2008, 06:49:43 pm »
It's a 161 bulb, which means it's 12V.  Technically, it's 14V, but you'll be running it lower.
You could swap it out for a 5V bulb if you wanted, like a 555.
paulscade
« Reply #5 on: July 24, 2008, 07:39:46 pm »
That's what I needed to hear... tkx! Peale
