October 09, 2026, 07:00:23 pm
Thanks, after taking the protective cover off the back of the neck board, the middle transistor made the board black. So I am trying to find a replacement C3956 transistor. Radio Shack does not carry them and most places on-line want you to buy in quantities. I tried Mouser electronics too and they did not have them. Any suggestions?Thanks for your help...
You should see if you can locate someone with a CRT tester / rejuvinator to rule out the weak gun
