Author Topic: WG K7000  (Read 1363 times)
jaav
  • Last login:January 11, 2010, 02:38:27 am
WG K7000
« on: June 21, 2008, 10:56:50 am »
I have a K7000 that failed some time ago, replaced the reg, LOT and driver Has been fine, the tube is alittle low on emission, anyway it started to develop a vertical fault  so i did a recap. No more vert problems but now I have a horizontal convergence problem the 3 guns are way out.
in cross hatch mode the vert is nice and white but the horizontal you can see each RGB.
Ive rechecked the caps.
any clues What I may have done wrong.
Thanks Jim.  broome WAust...
grantspain
Re: WG K7000
« Reply #1 on: June 21, 2008, 11:07:30 am »
maybe you knocked the purity rings on the yoke whilst removing the chassis,they should all line up to a paint line
Ken Layton
  • Guru
  • Technician
Re: WG K7000
« Reply #2 on: June 21, 2008, 01:15:04 pm »
Yup, you must have bumped the yoke or the purity/convergence rings on the neck.
