Author Topic: Vision Pro and ground wire  (Read 1541 times)
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
« on: June 15, 2008, 09:36:00 pm »
I replaced a monitor in one of my cabs with a Vision Pro, and I'm no longer using the cab's power via the isolation transformer (I'm plugging the monitor straight into a power strip).
Do I still need to connect the cabs green grounding wire to the new monitor? I'm assuming I don't, since the monitor plugged into the powerstrip should be grounding it.  Would it hurt things if I did connect the green wire to the monitor?
As you can tell, I'm no expert on grounding.   :P
grantspain
  • Last login:Yesterday at 03:33:53 pm
Re: Vision Pro and ground wire
« Reply #1 on: June 16, 2008, 02:35:19 am »
reconnecting the earth should not make any difference
