Author Topic: vga pinout help needed  (Read 2461 times)
Denverlatino
  • ---Buyer Beware - transactions with this user are in dispute--- ... Banned ...
  • Last login:May 13, 2009, 02:55:24 pm
« on: June 09, 2008, 01:00:49 pm »
i posted here http://forum.arcadecontrols.com/index.php?topic=80977.0
but could not modified the topic so started this new one.
I manage to find red green and blue  plus ground connections on the monitor, mi qwestion is,
can a monitor only work with those and ignore the rest of the cables.
Because i cant figure what the 12 remainding cables are for, probably they are for the touch screen function.
Thanks for any help.
[transactions in dispute -- see http://forum.arcadecontrols.com/index.php?topic=77030.0]
... Banned ...
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
Re: vga pinout help needed
« Reply #1 on: June 09, 2008, 09:58:32 pm »
There should be a couple for each of the three colors, and a couple more for the Horz & Vert sync.
BASS!
  • Just have fun.
« Reply #2 on: June 10, 2008, 01:17:54 am »
I would say it would work unless you have connected the signals wrong. Why not just try and see what happens. Those other 12 pins are most likely just the power/ground and signal for the touchscreen functions. The very worst is the monitor would not detect the touchscreen and would go into power save. Most likely it will just work like normal. If you want to throw the model up here and someone may have more info on the screen you are using and a pinout of the connector so that you can use the touch functions.
northerngames
  • Trade Count: (+18)
« Reply #3 on: June 10, 2008, 07:29:39 am »
Your after the red green blue ground H and V to get a standard display.
Denverlatino
« Reply #4 on: June 10, 2008, 10:55:45 am »
the harness has 4 sets of cables wraped in foild they are the green , red, blue, and one grey, does that means that grey its for both h and v or im i missing one cable has well, maybe ill post pics today. ill try today, and post results.
by the way , display model is  Micros ASM Eclipse display active 400497-002
... Banned ...
northerngames
« Reply #5 on: June 10, 2008, 11:50:04 am »
more then likely it is the composite sync wire where H and V are together.
Denverlatino
« Reply #6 on: June 10, 2008, 02:02:19 pm »
so those that means i can just buy a female vga imput, solder the cables where they belong, red in pin 1, green pin 2,blue pin 3, and sync on 13, and ill have a basic display, no need of monitor id bits or vertical sync at 14.
Im i right?
... Banned ...
northerngames
« Reply #7 on: June 10, 2008, 03:16:01 pm »
You will also need to find the ground
 If it is going to run composite and has it's own path the v can be left alone.
« Last Edit: June 10, 2008, 03:17:46 pm by northerngames »
Denverlatino
« Reply #8 on: June 10, 2008, 04:32:58 pm »
every single foiled cable has its own ground atached as well, il have to waith unti i get home to solder and see what happens, hanks allot for your help.  :cheers:
... Banned ...
