Author Topic: ArcadeVGA and V-Sync not working  (Read 1329 times)
Haggar
  • Last login:February 13, 2017, 05:12:32 am
« on: May 27, 2008, 05:00:27 am »
I use an ArcadeVga (9250 model) with an arcade 15KHz monitor.
Mame runs fine with ddraw and V-Sync option activated.
I have problems with these emulators:
- ePSXe (Playstation emu)
- Mednafen (PC-Engine and other systems emu)
- Visual Boy Advance (Gameboy Advance emu)
I use 640x240 and 640x480 resolutions (the problem remains the same also with other resoluitions).
The problem is that I've turned V-Sync option ON in the emus config, but I have tearing (classic image distortion due to a disabled V-Sync).
-  ePSXe uses Pete's D3D6 plugins.
-  Mednafen and Visual Boy Advance uses OpenGL.
I've tryied installing "Ati Tray Tools" and I have forced "V-Sync ON" both for D3D and OpenGL, but V-Sync remains OFF for that 3 emus.
Maybe is an arcadevga drivers issue?
Any suggestion?
PS: The strange thing is that V-Sync works with no problems with other emus like ZSNES and KEGA Fusion...
