Author Topic: Can it be done?  (Read 1861 times)
newbee
  • Last login:August 23, 2009, 01:56:27 pm
Can it be done?
« on: May 26, 2008, 02:44:32 pm »
Is it possible to launch MAME32, from a slave hard drive???
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
Re: Can it be done?
« Reply #1 on: May 26, 2008, 03:42:37 pm »
 Not sure about Mame32 but I can successfully launch Mame Plus
from a slaved Hard drive. I can only assume it would be the same?
*** Teutonic Darkness ***
Twin-X
  • Last login:April 26, 2018, 05:59:44 pm
  • Yes this avatar was stolen too!!!
Re: Can it be done?
« Reply #2 on: May 26, 2008, 04:10:18 pm »
Yes you can even run it from a network share.
daywane
  • GRRRR!
Re: Can it be done?
« Reply #3 on: May 26, 2008, 08:52:52 pm »
sure. most of my PC's have a small main drive and a large slave.
copy short cut to desktop or startup folder.
you can even have it on CD od DVD
there are some CD's around that boots at startup but I have never had luck with em. (mame boot disks)
there just more work than I care to put in them.
« Last Edit: May 27, 2008, 06:11:41 pm by daywane »
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
Re: Can it be done?
« Reply #4 on: May 26, 2008, 08:55:33 pm »
I have thumb drive with mame32 and games on it and it plays fine
I b**ch. People listen!!
newbee
Re: Can it be done?
« Reply #5 on: May 30, 2008, 03:28:17 pm »
 What version of Mame, are you using, on your flash drive?
 Would you have the proceedure, on how to load Mame to your flash drive, and launch the program?
squirrellydw
Re: Can it be done?
« Reply #6 on: May 30, 2008, 11:47:58 pm »
Just copy mame32 to the thumb drive and load any games you want to the correct directory.  Insert the thumb drive, launch mame32.exe, find the game you want to play that you copied to the directory and play away.  I use version 113 since that is what my rom set is
newbee
Re: Can it be done?
« Reply #7 on: June 01, 2008, 11:21:05 am »
 Thank you all, for your help.
