Author Topic: Scored a working MB Widebody $70.00  (Read 2270 times)
WunderCade
« on: May 24, 2008, 09:46:32 pm »
Everything works except the previous owner removed the monitor after breaking the neck tube.
I have a spare working 19" Wells Gardner K4625 that I can put in it. Will it work as a replacement for the MB Sanyo monitor without any modifications? Do I need an inverter or some kind of converter or adapter?
Thanks guys...I'll get a thread with pics up over on the Main forum.
SirPeale
  • Green Mountain Man
Re: Scored a working MB Widebody $70.00
« Reply #1 on: May 24, 2008, 10:56:53 pm »
Sanyo EZ takes 100V, while a K4600 takes 110.
WunderCade
« Reply #2 on: May 24, 2008, 11:22:03 pm »
Thanks Peale. Anyone know of a solution or workaround to get the 110V to a WG K4600 in this scenario?
...other than buying a Sanyo 20EZ?  ;D
SirPeale
« Reply #3 on: May 25, 2008, 12:22:01 am »
Replace the isolation transformer.
WunderCade
« Reply #4 on: May 25, 2008, 10:54:42 pm »
Thanks Peale...
One more thing....since I'm not using a Sanyo EZ, does that mean I don't need an video inverter? Not sure if the MB game had that issue like the DK, DK Jr. does?
SirPeale
« Reply #5 on: May 25, 2008, 11:42:08 pm »
The video inverter is usually *on* the Sanyo EZ.  You should be good to go once you replace that iso.
Level42
« Reply #6 on: May 26, 2008, 06:05:33 am »
That's a total STEAL deal ! Congrats. We want piccies !
Peale, if the video inverter is ON the Sanyo, shouldn't one be added "on/between" the WG ?
If the MB PCB set sends it out inverted, it will arrive inverted at the Sanyo that inverts is, but the WG won't, so you'll get an inverted picture right ? Or am I missing something ?
SirPeale
« Reply #7 on: May 26, 2008, 08:25:05 am »
Oh yeah...forgot about MB.  Does it output inverted signal?
