Author Topic: Any way to control ATI's YPbPr output to generate 240p?  (Read 1661 times)
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« on: May 14, 2008, 12:05:49 pm »
I have run into some ideas regarding the use of RGB to YPbPr transcoders in conjunction with WinModelines (or Soft 15kHz) to generate 240 progressive on a standard TV through the component inputs.
Is there any way to directly control the component output from ATI Radeon cards to produce 240p rather than 480i without the use of external transcoders?
"The Manuel"
