Author Topic: Mamewah shell shutdown  (Read 4632 times)
ScooterMAC
  • Last login:April 15, 2012, 12:47:20 am
« on: April 28, 2008, 11:32:39 am »
I am running mamewah 1.62 shelled in xp home. I have set the exit_and_run_app_commandlines to c:\windows\explorer.exe (explorer.exe wouldn't work for me) and exit_action to choice. It works great when I need to go into windows. The problem I am having is when I select reboot or shutdown in the option screen its loads to windows desktop and does nothing. I have searched around the forum and couldn't find anything about this. I sure it can be done, I just don't know how. Thanks.
« Last Edit: April 28, 2008, 11:38:57 am by ScooterMAC »
Kick Ass!
Re: Mamewah shell shutdown
« Reply #1 on: April 30, 2008, 01:21:37 pm »
Perhaps running Mamewah as shell causes some problem with shutting down....but then again I am pretty sure other people do this successfully.  Can anyone confirm?
ScooterMAC
« Reply #2 on: May 06, 2008, 05:27:29 pm »
Any suggestions MINWAH?
Kick Ass!
« Reply #3 on: May 07, 2008, 06:15:13 am »
Try running Mamewah normally (not as your shell), and see if the same thing happens. At least that will tell you if shelling Mamewah is causing this issue.
ScooterMAC
« Reply #4 on: May 07, 2008, 09:49:30 am »
Mamewah works fine when not shelled. I think its the exit and run application command.  Is there any way to map each choice to a specific option?
MAMEWAH (in game) Options:
Exit to windows | c:\windows\explorer.exe
Restart | c:\windows\shutdown -r -t 0 or c:\Windows\RUNDLL.EXE user.exe,exitwindowsexecexit
Shutdown | c:\windows\shutdown -f -t 0 or c:\Windows\RUNDLL32.EXE user,exitwindowsexit
I havent tried any of them yet, so the commands may not work. Just trying to see if it's possible.
Thanks.
« Last Edit: May 07, 2008, 10:01:28 am by ScooterMAC »
Kick Ass!
« Reply #5 on: May 07, 2008, 11:21:21 am »
Not exactly, but you probably could run those commandlines as an application if you really wanted to using the 'general_app_commandlines' setting.
It would be good to know if anyone else has this problem, I don't recall anyone else mentioning this.
ScooterMAC
« Reply #6 on: May 07, 2008, 03:13:02 pm »
[/quote]
[/quote]
I think most people have their computer power switch on the front. I have mine computer plugged into a power strip and the stip is wired to a toggle switch that is on the side. I'm just worried about crashing my computer with the hard powerdowns.
Kick Ass!
ScooterMAC
« Reply #7 on: May 07, 2008, 03:13:56 pm »
Kick Ass!
ablizno
  • Last login:August 15, 2011, 09:04:29 pm
  • [insert text here]
« Reply #8 on: May 07, 2008, 04:20:56 pm »
when u hit player 2 button there should be an option to quit and shutdown. It works for me. Also can u post a picture of how u wired your power strip to a toggle switch because i am looking to do the same thing but can not figure out how to do so.
ScooterMAC
« Reply #9 on: May 07, 2008, 07:33:35 pm »
Not sure how your setup is, but every one is different. Mine is escape. I had a hour to kill at work so I made this crappy drawing of how it goes together. This is a very basic setup so you should have no problem. I used a heavy duty 20a toggle switch and a 15a power strip. Everything is off the surge protector and if there is a surge it will just shut off not damaging anything. Always use a multimeter and check your connections! If you need help just let me know. I will post a pic when I get home. MS Paint (NT) rules!
Kick Ass!
ScooterMAC
« Reply #10 on: May 07, 2008, 08:56:41 pm »
I made this panel out of stainless steel and mounted it on the side of my cp. It's the main power and volume control.
Kick Ass!
ScooterMAC
« Reply #11 on: May 07, 2008, 10:28:23 pm »
OK, I've narrowed it down (I think) to :
### External Application Settings ###
startup_app_commandlines
exit_app_commandlines                     explorer.exe
Before I had c:\windows\explorer.exe and I changed it explorer.exe. It worked!But....when I exit to windows it doesn't bring up explorer. Only a blank screen, in which I have to ctr+alt+del - run - c:\windows\explorer.exe. Any sugestions?
Kick Ass!
  • Last login:April 19, 2026, 07:24:05 pm
« Reply #12 on: May 07, 2008, 10:50:39 pm »
Not sure if this will work or not, but try:
exit_app_commandlines                   start  explorer
ScooterMAC
« Reply #13 on: May 08, 2008, 12:21:24 am »
I tried that but no luck yet. Here is my ini file:
### mamewah.ini (mamewah v1.62) ###
### (Global) Screen-Saver Settings ###
delay                                     60000
slide_duration                            2
### Audio Settings ###
enable_sounds                             1
sound_volume                              80
music_path                                c:\music
enable_music                              1
music_volume                              100
### Movie Settings ###
intro_movie_file                          c:\intro
exit_movie_file
keep_movie_preview_aspect                 no
delay_before_movie_preview                2
music_movie_mix                           mute_movies
movie_volume                              90
### Misc Settings ###
emulator_root_path
auto_setup_emulators                      0
theme                                     (Default Layout)
wrap_list                                 1
remember_current_game                     1
keep_image_aspect                         1
refresh_images                            1
delay_before_history_dat                  2
safe_mode                                 0
show_cursor                               0
keyboard_led_states                       -,-,-
lcd_com_port                              1
lcd_settings
exit_action                               choice
maxlogsize                                100000
### Settings used by MAMEWAH ###
current_group
current_emulator                          mame
locked                                    0
Kick Ass!
« Reply #14 on: May 08, 2008, 04:32:03 am »
I will have a play around with this today and see what I can come up with.
« Reply #15 on: May 08, 2008, 09:23:33 am »
Try this:
exit_app_commandlines             c:\windows\explorer.exe{nowait}
Mamewah expects full paths, so definately leave the 'c:\windows\' part in.  The {nowait} part will quit Mamewah as soon as explorer is launched.
exit_and_run_app_commandlines could be used to run a commandline to shutdown the PC, but remember you would have to exit Mamewah in the correct way (either Exit & Run Application from the Exit menu, or set 'exit_action run_app' in mamewah.ini, or setup a suitable shortcut in mamewah.cfg.
ScooterMAC
« Reply #16 on: May 08, 2008, 11:00:17 pm »
IT WORKED!!!!!!!!!!!!!!!!!Thank You very much Minwah! I'm just wondering why the {nowait} had a big effect. I did notice that if it was not there, windows had mamewah still running under task manager. Well whatever, it's fixed and your the man! :cheers:
Kick Ass!
« Reply #17 on: May 12, 2008, 05:09:01 am »
If {nowait} is not present then Mamewah will wait for the app to finish (ie as you saw, Mamewah will still be running).
Glad it worked!!  8)
ScooterMAC
« Reply #18 on: May 12, 2008, 09:06:20 pm »
One more question minwah....is there a {wait} command? I have a intro video but I would like it to delay a couple of seconds to let the apps in the backround load up (nvida). Thanks.
Kick Ass!
« Reply #19 on: May 13, 2008, 06:39:22 am »
Yes, but it is default if {nowait} is not specified. It makes Mamewah wait for the app to finish execution.
If you are running the nvidia app from Mamewah (using startup_app_commandlines), then it should wait for it anyway (assuming {nowait} is not specified).
