Author Topic: Using LED on Mamewah  (Read 1238 times)
ace3093
  • Last login:May 20, 2012, 03:29:12 am
« on: April 23, 2008, 04:29:18 pm »
I am currently using Gameex and there is a plug-in that controls my lighted LED pushbuttons. I just started messing around with mamewah and I am looking to see if there a similar option to the plug-in for Gameex for mamewah?  I am using a pacdrive's to run my LED's.
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Using LED on Mamewah
« Reply #1 on: April 24, 2008, 03:59:26 am »
You can use Arzoo's plugin's .  It works For Mala, GameEx, AtomicFe, MameWah and all front end that can run external application.
check this thread:
http://forum.arcadecontrols.com/index.php?topic=73905.0
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #2 on: April 25, 2008, 08:29:39 am »
ace3093,
If you decide to try LEDBlinky with mamewah, you'll need a patch (which I have yet to post on the LEDBlinky support thread). Send me a pm and I'll get you the patch.
youki - thanks for the help here!
Robots will kill you.
Arcade Addiction
