Author Topic: arcade vga  (Read 1865 times)
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
arcade vga
« on: April 14, 2008, 03:49:09 pm »
i just built a 27 arcade monitor and what i want to know is will the arcade vga be any better than the radeon 9200 card I'm using now with soft 15
ahofle
    • Arcade Ambience Project
Re: arcade vga
« Reply #1 on: April 14, 2008, 04:04:24 pm »
The main benefit (other than ease of use) of the AVGA is the fact that the boot/POST screens are 15khz, whereas they are VGA when using Soft15khz.  I'm also having some problems with certain resolutions missing in Soft15khz that work fine in the AVGA.  But I'd say that if you have a card that has all the resolutions available with Soft15khz and you don't need to worry about the boot screens, then Soft15khz is just as good or better IMO.
alienware32
Re: arcade vga
« Reply #2 on: April 14, 2008, 04:27:37 pm »
i think ill getit because i dont want to damage my monitor
